Author Topic: gen light wont turn off  (Read 2075 times)
studebaker04
« on: July 10, 2012, 09:39:09 PM »
Hey guys,
    I turned my bike off today 1982 r65. When I took the key out the gen light turned turned on and won't go off. Any ideas?
Thank you.
Re: gen light wont turn off
« Reply #1 on: July 10, 2012, 10:12:00 PM »
Failed diode in the diode board, is my first guess .
You may want to disconnect your battery, or it will be discharged overnight .
« Last Edit: July 10, 2012, 10:12:51 PM by Bob_Roller »
« Reply #2 on: July 10, 2012, 10:12:52 PM »
It may be a bad diode in the diode board, though there are some more "subtle" failures which could also cause this to happen with the key switch off.   The key switch itself should turn off power to the gen light/voltage regulator/rotor excitation circuit with the key "OFF".  If you are able to turn off & remove the key, and have the light(s) remain on (is it just the GEN light, or do other dashboard lights work?) it is possible that there may be something faulty with the switch, or it hasn't been wired correctly.  Has any work been done to the bike recently?
Does the light ever go off after you've started the bike and get the revs over 2000 rpm or so?   Or, perhaps the battery is pretty much drained by morning?
« Last Edit: July 10, 2012, 10:26:42 PM by nhmaf »
studebaker04
« Reply #3 on: July 10, 2012, 11:11:54 PM »
when i turn the key to the on position the gen light turns off the neutral and oil come on. the gen light is the only thing that stays on. can I disconnect the diode board?
studebaker04
« Reply #4 on: July 10, 2012, 11:39:16 PM »
Update battery dead. Can I replace the whole gauge assembly my speedo does not work anyway.
« Reply #5 on: July 11, 2012, 06:23:15 AM »
Are you saying the problem was caused by a dead battery or that your battery is now dead?
The GEN lamp and circuit is more than just an idiot light. The bulb is a key component of the exciter circuit that is required to get the alternator to begin charging the battery. If you have a burned out GEN bulb, your battery will soon go flat.
To answer your question; you would need to add a resistor into the GEN lamp circuit to fool the alternator into going to work. Snowbum has the details on how to do it. I have installed these safety circuits on both my R65s.
« Reply #6 on: July 11, 2012, 07:56:25 AM »
The diode board, is under the front engine cover .
It serves the same purpose that the diodes in your auto alternator do, they are just seperate and can be easily changed .
studebaker04
« Reply #7 on: July 13, 2012, 08:17:17 PM »
I agree that it must be the diode. Does any one have a link to how to repair it?
« Reply #8 on: July 13, 2012, 08:24:30 PM »
It's a remove and replace type item .
Here's a link to what it looks like .
http://www.euromotoelectrics.com/BMW-R-Airhead-Diode-Board-12-31-1-244-06-p/boalt-rect063.htm
« Last Edit: July 13, 2012, 08:51:16 PM by Bob_Roller »
studebaker04
« Reply #9 on: July 13, 2012, 09:06:21 PM »
Good deal thank you. Is this the best way to go?
« Reply #10 on: July 13, 2012, 09:11:12 PM »
If you know how to check diodes, it's best to confirm the diode board is the problem .
studebaker04
« Reply #11 on: July 13, 2012, 09:18:47 PM »
I am some what handy. Is it hard to check diodes? Is there a way I can repair the board?
« Reply #12 on: July 13, 2012, 09:39:12 PM »
You need a multimeter, to check the individual diodes .
The diode board is pretty much a remove and replace item .
« Reply #13 on: July 13, 2012, 09:52:22 PM »
For a full dissertation on the diode board, it's care and love and discipline, read Snownum's full thesis.
http://bmwmotorcycletech.info/
« Reply #14 on: July 14, 2012, 08:03:33 AM »
That's certainly what I'd do or at least attempt. There's nothing special about them they are just diodes of a certain current rating. One problem might be the grey paint on the board.
