Author Topic: Minor Induction Leak?  (Read 818 times)
Offline Air4Life
« on: June 27, 2012, 04:41:10 PM »
I wanted to replace all four of the "grommets" yesterday.  So I had removed a set from one side for comparison. I later placed them back on.  I also readjusted the angle of the other carb, along with the clamps.  After tightening the whole thing down and test running it, I immediately noticided that it no longer requres choke at these temps.  Today, more of the same.
Coincidence, I don't think so, but who can say for sure.  I have some doubt because I would have thought my idle would have needed readjustment, which is not the case.  So with that, I'm not 100% sure.   What am I missing?
sold:
1983 33.8 E. Oil & Trans ?
Batt 10/06/2011
RearT 35.5 Spline 7/12 &
T.O.Bearing
C.U. Paste 5/12
Re: Minor Induction Leak?
« Reply #1 on: June 27, 2012, 05:06:41 PM »
Angle of the carb could alter the effective float level ?
but yes you might have cured an air leak and changing the mixture unless it was a long way off wouldn't necessarily change idle speed which can be stable across a range of mixture strengths and only falls with extreme lean or rich mixtures.
« Last Edit: June 27, 2012, 05:15:05 PM by bhodgson »
