Author Topic: Swingarm maintenance.  (Read 958 times)
Ron_S.
« on: May 11, 2012, 02:27:56 PM »
I'm going through my very first annual maintenance on my 86 R65.  How do you get the swingarm bearings greased and be sure you got grease to the right places?  What's a tapered grease fitting/head?  I've greased a lot of farm and construction equipment and never heard of that.
Re: Swingarm maintenance.
« Reply #1 on: May 11, 2012, 02:32:03 PM »
You'll need a pointed greasing tip on the grease gun. Remove the black plastic covers to get to the greasing point which is in the center of the swingarm axle. It's greased when it spurts out around the swing arm axles - between the frame and swingarm.
« Last Edit: May 11, 2012, 02:34:00 PM by tvrla »
Ron_S.
« Reply #2 on: May 11, 2012, 02:34:53 PM »
Thanks.  I popped off that cap and the whole area inside is full of grease.  Is it supposed to be?
« Reply #3 on: May 11, 2012, 02:45:55 PM »
It keeps water from getting to the bearing .
Ron_S.
« Reply #4 on: May 11, 2012, 02:47:16 PM »
Thanks.
« Reply #5 on: May 11, 2012, 05:23:50 PM »
...  I've greased a lot of farm... equipment and never heard of that.
Bought my swingarm bearing grease gun rubber pointy tip thingy at Tractor Supply. Couple bucks.
Offline Air4Life
« Reply #6 on: May 12, 2012, 03:09:13 PM »
When I couldnt locate my pointy tip  I just used the traditional zerk and made sure it was square as I injected the grease.
« Last Edit: May 12, 2012, 03:09:54 PM by Air4Life »
sold:
1983 33.8 E. Oil & Trans ?
Batt 10/06/2011
RearT 35.5 Spline 7/12 &
T.O.Bearing
C.U. Paste 5/12
« Reply #7 on: May 12, 2012, 04:11:59 PM »
One version:
Unfortunately the link from where I got that image is broken (requires name & password!).
But it gives you an idea of what you are looking for.
The one I personally have is much bigger & messier (IMO), but they seem to be easy to find in auto parts stores:
The first one replaces the female zerk fitting on your gun.
The second one has a male zerk to quick-connect to the gun.
I still want to find one of the first ones....
[size=14]BINGO!  TractorSupplyTractorSupplyTractorSupplyTractorSupply[/size](Thanks Monte!)
http://www.tractorsupply.com/workforce-reg-seal-off-coupler-with-rubber-tip-3952751
« Last Edit: May 12, 2012, 04:18:24 PM by Rob_Valdez_79_R65 »
Ron_S.
« Reply #8 on: June 01, 2012, 02:04:14 PM »
Great!  We have a Tractor Supply right on my way home.  Thanks a ton.
