Author Topic: exhaust leak Valve cover  (Read 876 times)
jg928s4
« on: June 01, 2012, 12:25:06 AM »
Seems I see exhaust leeking out of the valve cover.  Ideas?
Re: exhaust leak Valve cover
« Reply #1 on: June 01, 2012, 07:45:19 AM »
More details, please.
Smoke? oil drips? Confirm exact location, if possible.
« Reply #2 on: June 01, 2012, 07:53:40 AM »
Most lilely a leaky valve cover gasket and what you are seeing is the atomized oil that is usually in the crankcase air while the engine is running .
With both pistons on the downstroke, the crankcase pressure gets pretty high .
Forget to put the oil level dipstick back in, or forget to tighten it up, you'll see how much pressure is in the crankcase, when you start the engine .
« Last Edit: June 01, 2012, 09:04:56 AM by Bob_Roller »
