Author Topic: Magura L-463-00 handlebars  (Read 1070 times)
jgp1854
« on: May 24, 2012, 12:34:41 PM »
Need a little information on the Magura bars.  Can anyone tell me what the inside diameter is???  I trying to install some Napoleon (or other manufacturer) bar end mirrors on my LS.
Thanks
JGP
Re: Magura L-463-00 handlebars
« Reply #1 on: May 25, 2012, 12:44:33 AM »
The Napoleons fit just fine. I know, cause I've used them.
Can't answer your question at the moment about inside diameter.
Offline Julio A.
« Reply #2 on: May 25, 2012, 11:28:15 PM »
Napoleons fit just fine on the maguras. Just a warning, do not over tighten them as the rubber spacer that holds it in place may tear.
Julio Alarcon
1981 R65
1976 R90/6
2001 R1150 GS/ADV
2015 TR650
« Reply #3 on: May 26, 2012, 06:17:52 PM »
I've been meaning to find some of those split metal anchor bolts to refit/replace the rubber gizmos on my napoleons - less likely to bind up on the throttle tube, though the rubber mounting does help reduce vibration in the mirrors.
« Reply #4 on: May 27, 2012, 09:21:28 AM »
Know what you mean! I went to a bicycle shop looking for a seatpost/gooseneck style clamp in that size, but there's nothing that small. Guess I'll have to make some myself.
« Reply #5 on: May 27, 2012, 10:40:10 AM »
Mike, for a possible source for those metal, split tube/expanding anchors, head back to your local hardware store and check out the masonry anchor selections. Many different sizes of pot metal, threaded/expanding anchors. Might have something that will work for you and others.
Sorry, 'Spokes, but ain't seen anything -yet- big as a bicycle seat post. :-/
