I'm not real sure, but there needs to be enough clearance to get the drive shaft out of the housing, in case parts need to be replaced .
A few members here, including myself have 120 width rear tires installed, I can only speak for the Metzler Lazertec tires that I have used .
A 120 width tire is a real pain to get off and on the bike, you need to deflate the tire to get it out, even then, it's a lot more work than it should be .
The are different length flanged spacers that stick out of the wheel bearing area on the wheel .
You can move the tire/wheel over, to where you may be able to get a 130 width rear tire on, but you would be in unknown territory there, as to whether it really would work .
With that width tire, you may need to remove the left shock absorber and muffler to get it off and on .
