Author Topic: Key copies ?  (Read 1363 times)
apaiva
Key copies ?
« on: May 08, 2012, 04:51:54 PM »
My R65 only came with one key so obviously it would be a good idea to have some copies.  Do I have to do this through a bmw dealer, or can I order appropriate blanks online and have a typical hardware store make copies?
If so, where can I find the blanks?  I checked ebay and didn't see there but did find what looks like what I want at A&S Cycles
http://search.ascycles.com/search?w=r65%20key
thanks,
Re: Key copies ?
« Reply #1 on: May 08, 2012, 05:20:36 PM »
I've gotten duplicate keys made at local Locksmith shops without any difficulties .
Hardware stores, or home improvement stores may not have the correct blank available .
anaxolotl
Re: Key copies ?
« Reply #2 on: May 08, 2012, 06:07:17 PM »
my bike only came with one as well, so after a couple weeks of being concerned i would lose/break it i purchased two blanks from ebay (this seller: http://myworld.ebay.com/etj2?ssPageName=ADME:L:OC:US:1181).  I actually had a bit of trouble trying to get the keys cut as the first three places i brought it said they couldn't/wouldn't cut steel keys.  Finally I found a locksmith that would cut them for me (at 5.99$ a piece.. which at that point, i was happy to pay)
Re: Key copies ?
« Reply #3 on: May 08, 2012, 10:42:58 PM »
Yes, soem of the BMW OEM keys are stainless steel blanks - very durable, but hard to cut and quickly dulls lower-end key cutting wheels like you'd find at common hardware stores - so they will often refuse to cut them.   I have gotten keys made at a locksmith in town, who had blanks as well.
bruce_launceston
Re: Key copies ?
« Reply #4 on: May 09, 2012, 02:14:47 AM »
I have also bought the genuine folding blank keys for about $12 each and the local locksmith cuts them no problems at all.
Re: Key copies ?
« Reply #5 on: May 09, 2012, 04:17:20 AM »
When looking for key blanks it might help to know they are made by Neiman.
Lots of info on keys here:-
http://w6rec.com/duane/bmw/keys/index.htm
apaiva
Re: Key copies ?
« Reply #6 on: May 09, 2012, 08:48:12 AM »
great. thanks for the info dudes.
Re: Key copies ?
« Reply #7 on: May 09, 2012, 08:52:34 AM »
After the key is made, it may not work when you put it in the lock, there's a lip on the key that prevents it from going in all the way .
Put your original key next to the duplicate and it will be obvious what bit of metal needs to be removed with a file, to let it go into the lock all the way .
At least on the Ilco key blanks .
« Last Edit: May 09, 2012, 08:53:40 AM by Bob_Roller »
