Author Topic: Frame Bearing "cups"  (Read 801 times)
« on: April 21, 2012, 09:26:02 AM »
Hi All,
I need to remove the cups that seem to be press fitted into the frame stem head prior to the powder coater shotblasting and painting the frame. I can't seem to found out how to remove these, can anybody assist please?
Thanks
Chris
Re: Frame Bearing "cups"
« Reply #1 on: April 21, 2012, 09:58:11 AM »
You need some specialty tools to get the outer race removed .
Here's a couple of examples of the tools, may be able to put together a homemade tool yourself .
http://www.cycleworks.net/index.php?main_page=product_info&cPath=29_33_50&products_id=62
http://www.cycleworks.net/index.php?main_page=product_info&cPath=29_33_50&products_id=63
« Last Edit: April 21, 2012, 10:00:59 AM by Bob_Roller »
« Reply #2 on: April 21, 2012, 10:23:29 AM »
A cut-off wheel mounted to your Dremel can be used to split the outer race and it will then be easily extracted.
Other recommendations involve zapping a couple arc beads on the outer race and removing it; so say "they". Never seen it done.  Another ghetto removal technique is to drill a couple angled holes through the frame neck to access the outer race. Then use a drift to knock it out. Not my style, that.
Either way, you will likely need new bearings if the outer races are even the tiniest bit damaged during removal.
Then there's the whole correct refit procedure.
Might you call and/or haul the frame to a BMW dealer and check if they have the correct tooling to remove the races?
I have Dan's complete stem bearing removal and refit tools. Well designed and worth the price. The job can be tedious but with the right tools, it's one time and done.
« Reply #3 on: April 21, 2012, 11:17:01 AM »
Thanks Guys,
Very helpful.
Chris
