Author Topic: Neiman locks  (Read 768 times)
Boxer_Bolshie
Neiman locks
« on: April 07, 2012, 03:02:21 PM »
After removing the Neiman lock from my forks, at the beginning of my R65 restoration, I cleaned and buffed it up to remove all the grime and tarnish.  While buffing the lock cylinder I watched as the tiny screw, that resides in the "slide channel" on the side, fly out and across the shed where it disappeared (probably) forever.  Ever since I have been searching high and low for another screw to replace the one I lost.
Does anyone know where individual Neiman lock parts might be had?
Re: Neiman locks
« Reply #1 on: April 07, 2012, 03:20:27 PM »
You may want to try a clock repair shop that works on mechanical clock movements .
Re: Neiman locks
« Reply #2 on: April 08, 2012, 03:45:06 AM »
You might also try Model Engineering suppliers as they often stock very small screws.
Assuming the screw was metric then the sizes available are M1.0 M1.2 M1.4 M1.6 M1.7 M2.0
« Last Edit: April 08, 2012, 04:00:10 AM by bhodgson »
