Author Topic: Glass Beading Clean-Up Question  (Read 2688 times)
Offline Dave 2
« on: March 26, 2012, 09:47:34 AM »
Here are a few pictures of the progress that I am making on cleaning up the Cylinder Heads. They required a good deal of hand cleaning before I glass beaded them. They came out of the beading looking good if I do say so myself. I have one big concern about glass bead residue. I did not remove the valves before I blasted them and I used compressed air to clean off the beads when I was finished. They appear to be bead free but I'm wondering if I should have the valves removed and then clean everything again?  Or is there some way of additional cleaning, without removing the valves, to be sure that any bead residue is gone? Any thoughts? I know that glass beads can do damage...Thanks D2
Re: Glass Beading Clean-Up Question
« Reply #1 on: March 26, 2012, 09:52:12 AM »
I would suggest removing the valves and do a cleaning then, there's no way to get all of the blasting media out of there with them assembled .
To look at it another way, glass beads are just fused sand, so now you have an undetermined amount of 'sand' in there .
« Reply #2 on: March 26, 2012, 10:05:54 AM »
I've heard too many stories of sand or glass beads remaining imbedded or lodged everywhere, even places blocked to them, to ever consider using that media for engine cleaning.
Guys who have successfully used this cleaning method also wash the parts many times over to ensure all grit is removed. I'd use a dental pick to ensure the plug threads are all clear. Make absolutely sure there's no grit in the head bolt channels, pull the valves (ensure no grit is on the top of the stem to score the valve guide) making sure to remove the ridge before withdrawing (standard practice).
Time may have been saved by blasting, but now it's best to spend it on cleaning. Bake the heads at 200 degrees, wash in hot soapy water, dry, and do it over again. You can't be too careful! Inspect every nook and cranny! And be meticulous about it.
Offline Dave 2
« Reply #3 on: March 26, 2012, 10:37:56 AM »
Thanks for the information and confirmation about just how damaging the beads can be. I will have the valves removed or get a tool to do it myself, and clean the daylights out of everything. [smiley=bmw_smiley.gif] D2
« Reply #4 on: March 26, 2012, 10:46:21 AM »
Less aggressive blasting media is available, walnut shell, or other 'organic' materials, plastic,  take a bit more time to get things cleaned up, but you don't have as much of a concern about contamination afterwards .
« Reply #5 on: March 29, 2012, 03:38:04 PM »
Dave,
I'm in the process of getting my engine parts vapour blasted and have been advised to clean clean clean, the oilways could be an issue...
IMO, it's a small price to pay for the finish, just wish the P/O had looked after the bike properly and put it into storage properly, then I wouldn't have had to do so much cleaning!!!! >:( >:( >:(
« Reply #6 on: March 29, 2012, 07:33:56 PM »
Then again, he'd probably have asked a whole lot more than you paid!  ;)
« Reply #7 on: March 30, 2012, 09:41:46 AM »
Wirespokes,
Yeah good point, I only paid $350 for it... 8-)
Boy, am I paying for it now...
« Reply #8 on: March 30, 2012, 07:17:47 PM »
LOL
We call that "sweat equity".  ;D
Good thing our time is free, huh?
« Last Edit: March 30, 2012, 07:19:01 PM by tvrla »
Offline Dave 2
« Reply #9 on: March 31, 2012, 08:17:59 AM »
I was spending way too much time and effort trying to clean up  some parts by hand and the results were disappointing. I love the finish that the glass beads give so I would rather take the time and be super careful with the post beading clean-up to get the "Look". Anyway the deed is done and now I will start to clean. D2
« Reply #10 on: March 31, 2012, 09:59:37 AM »
I think it might make a difference how high you set the pressure when blasting - doesn't really need to be very high at all - maybe 30 - 40lbs. It's less aggressive that way, but also doesn't imbed the beads as badly either.
« Reply #11 on: March 31, 2012, 10:29:07 AM »
I wonder, if the electrolysis method would work on aluminum ?
I know it works on iron / steel parts .
http://users.eastlink.ca/~pspencer/nsaeta/electrolysis.html
« Last Edit: March 31, 2012, 10:34:54 AM by Bob_Roller »
« Reply #12 on: March 31, 2012, 11:14:20 AM »
Don't forget about the soda blasting method.  It's posted somewhere on the forum.  As our British cousins would say, "works a treat" when cleaning grunge off of engine parts.  I soda blasted a couple of Bing carbs I picked up on ebay.  Monte soda blasted his fork legs.  Makes 'em look really good and dirt cheap.
Aha!  Found the original post from November 2009.
Soda Blaster for Carbs
Just enter that title into the search.   Since then I've used this for numerous parts and can attest to it's efficacy.
« Last Edit: March 31, 2012, 11:23:53 AM by Bengt_Phorqs »
« Reply #13 on: March 31, 2012, 01:20:13 PM »
Dave (and others),
I got my first lot of parts back from the vapour blasting guy, the wheels look amazing and the rear drive hub casing looks like new. I will post some photos to show just how good the finish is.
The guy that did them said the reason the finish is so good is that the end result is only as good as the quality of the casting, shows BMW quality after 31 years, 33k miles and no real care or cleaning...
« Reply #14 on: March 31, 2012, 03:52:37 PM »
I got my first lot of parts back from the vapour blasting guy, the wheels look amazing and the rear drive hub casing looks like new. I will post some photos to show just how good the finish is....
Chris will you Lacquer the parts or leave them alfresco?...i use walnut shell in my brass bullet casing cleaner which is non invasive and does a good job on black powder residue but not big enough for bike bits one of my friends does soda blasting which were i to do an engine rebuild i would use as the results are impressive and no risk of residue damage.
