Author Topic: bugger to start!  (Read 1660 times)
MR.E
bugger to start!
« on: March 28, 2012, 04:00:02 AM »
Ey up
Been getting out more on the bike recently but it's a bugger to start when cold.
with the choke on it'll cough & splutter for a while before catching good & proper.
Any ideas what it might need?
New HT leads, plugs, reset choke???
Thanks
Elliott
Re: bugger to start!
« Reply #1 on: March 28, 2012, 04:38:46 AM »
Elliott
Have you tried starting with no choke ?
With the temperatures that we have had in the UK recently mine is starting instantly on the button without any choke at all. I know it should need choke and the fact that it doesn't would usually suggest I might be a tad rich but the plugs don't indicate that and I still get 60 - 70MPG so there can't be much wrong with the mixture. If this weather keeps up I wouldn't expect to need the choke again until October.
« Last Edit: March 28, 2012, 04:42:02 AM by bhodgson »
« Reply #2 on: March 28, 2012, 09:55:23 AM »
What year bike do you have ?
What is your starting technique ?
There's a bit of technique required to start these bikes, the manual choke use, is a bit of an 'art', as compared to 'modern' bikes !!!!
MR.E
« Reply #3 on: March 28, 2012, 03:35:07 PM »
Elliott
cheers, tried it without choke but not done it any good.
MR.E
« Reply #4 on: March 28, 2012, 03:39:59 PM »
Bike is a 1981
Starting technique........hmmmmm..........
Well fuel on, 2 half twists of the throttle, choke on & wait!!!
Went in the garage tonight, and looked over carbs it would appear the choke cables have slipped (though there not cables - I fit a choke to the airbox & there the pushrod ones).
Tightened the cable & clamps back up on the right side - it's a fiddly job - and it fired pretty much straight away, now just need to do the left side!!!
Elliott
« Reply #5 on: March 28, 2012, 04:17:27 PM »
Starting Technique.
Try full choke on, no throttle until it starts to fire then just blip the throttle knock the choke down to half soon after then off after 1/4 mile. Maybe sooner in summer or March.
« Last Edit: March 28, 2012, 04:19:19 PM by Lucky_Lou »
MR.E
« Reply #6 on: March 28, 2012, 04:21:13 PM »
at the moment i run it for about 1/2 a mile before i turn off the choke.
it'll sometimes need to be 'tickled' at the lights within the first mile or two but then normally run well.
What oil do you use?
I'm running a 20/50w classic car oil, but sound 'tink-y' when warm (valves are set fine)
Thanks
« Reply #7 on: March 28, 2012, 08:54:46 PM »
Who woulda thought the chokes might not be working right.  ;)
(gotta be a smartass in every crowd, huh? - it's a dirty job but someone's gotta do it!)
It doesn't do any good to twist the throttle a couple times before starting. Won't hurt anything, but won't help the bike start. If the carbs had accelerator pumps, then it would deliver a squirt every time, but these don't.
The best thing is to leave the throttle closed when cranking, then hit it when it catches.
Offline donbmw
« Reply #8 on: March 28, 2012, 08:55:29 PM »
Has the bike been setting up for awhile. It sounds like you need to clean the carbs. Pull you bowl and look at the small fuel bowl for the choke system the jet from the main fuel bowl could be stopped up not letting fuel to the chocke system. When I bought the R90 I have it was at beginng of summer and it was not until cold weather came that I found this back hard to start and that one of the carbs had the choke system stopped up. After I unstopped the jet to the choke system have not had any problems.
« Reply #9 on: March 29, 2012, 06:17:20 AM »
Cranking with the throttle closed and catching it with a quick blip is the classic airhead starting technique and there are a couple of reasons for doing it this way:
1. The choke isn't designed to function with the throttle open.
2. If you crank with the throttle open the starter will turn the engine over slightly slower as you are now asking it to work harder by compressing more mixture.
I also always start with the clutch pulled in to reduce the cold oil drag from the gearbox. Anything that makes it crank faster will help with starting.
« Last Edit: March 29, 2012, 06:19:28 AM by bhodgson »
« Reply #10 on: March 30, 2012, 02:25:44 AM »
Ahh but you live in the Tropics and your idea of "Cold" would be a beach day in Yorkshire... [smiley=thumbsup.gif]
I am running Castrol Classic GP50 (it was on offer i know tight git) what ever you use i would stay away from synthetics in the crankcase.
« Last Edit: March 30, 2012, 02:29:23 AM by Lucky_Lou »
