Author Topic: Replacing Final Drive Output Seal  (Read 1091 times)
« on: June 26, 2007, 02:28:23 PM »
Finally getting to replacing the final drive seal, along with the o-rings on the rear brake cam shaft. Any thing I should be warned about ahead of time? I don't think there are any tricks to it, but I just want to be sure. As it's getting too hot here ( 104 F. at 12 noon) to be messing with a project that will take longer than a couple of hours .
« Last Edit: June 26, 2007, 02:28:52 PM by Bob_Roller »
Chris_in_BC
Re: Replacing Final Drive Output Seal
« Reply #1 on: June 27, 2007, 02:54:09 AM »
Trying to remember whether this applies to my G/S or the R65 output seal cover. Think it is both.
Once the nuts are off, sometimes the cover doesn't want to lift and you shouldn't try levering with a screwdriver etc.. There are two threaded holes, I  think at 1pm and 7pm, probably covered in oil and muck. Takes  a 5 or 6mm bolt. Thread them in and tighten, it will lift the cover off.
Although BMW fiche showed a paper gasket under the cover, both my G/S and the R65 didn't have one there, so I kept the status quo. Just used some gasket goo.
« Reply #2 on: June 27, 2007, 09:43:54 AM »
Thanks Chris, I have a paper gasket if it is needed.
