Author Topic: Disc Issue  (Read 1507 times)
Disc Issue
« on: March 17, 2012, 02:53:21 PM »
Gertie has developed a very slight leak on one of the callipers, i am in the process of rebuilding the caliper this weekend for the MOT, there was evidence of "Blue staining" on the disc which i have steam cleaned to remove any brake fluid but wonder if i should attempt to polish the disc or do the herd think that would be overkill as the new brake pads will clear it ?.
Offline Mike V
  • 78 R100/7 , 81 R65
Re: Disc Issue
« Reply #1 on: March 17, 2012, 02:59:10 PM »
I would just break the glaze off of them and clean the holes out with a power drill and gun bore brush(s).  Mainly to give your new pads a nice clean abrasive surface to seat-in and burnish with.
I've had very good luck with my replacement OEM pads after a full disc cleaning, maintenance and tune-up.  Have you checked the runout on them?
Mike V. / San Diego
'78 R100/7 (original owner)
'81 R65 (fully restored)
Online Bob_Roller
Re: Disc Issue
« Reply #2 on: March 17, 2012, 03:10:12 PM »
I'm with Mike, 'scuff' up the surface of the rotor to get rid of the polished look .
Have you measured the thickness of the rotor ?
Re: Disc Issue
« Reply #3 on: March 17, 2012, 03:12:24 PM »
What would you suggest to break the glaze ? T Cut or something similar ? there is some grooving on the discs  but they appear to run true.  Dont think my 45/70 cleaning kit will fit the holes i will have to use one from my "Pea shooters" got some .36 pistol brushes they may do the trick.
Re: Disc Issue
« Reply #4 on: March 17, 2012, 03:15:44 PM »
I will check tomorrow if i am allowed in the garage on Mothers Day.... [smiley=whistling.gif]
Offline Mike V
Re: Disc Issue
« Reply #5 on: March 17, 2012, 03:44:02 PM »
Lou,
I'm trying to remember what I used on the holes...maybe ±30 caliber brushes?  I can check and get back to you.  A slightly larger brush works best, they will reduce in size but it makes relatively quick work chucked into a hand drill.
For the disc I just used a stiff sanding block and 320 grit.  And a comfortable seat with some chilled beverages.
One more thing, I've found new pad break-in to be very successful.  I do at least 30-50 30mph to 0mph aggressive stops with the new front brakes.  Making sure to allow adequate cooling after 5 or so stops.  This burnishing / break-in technique seems to all but eliminate brake squeal and glazing.  Light continuous braking on the front discs seems to create glazing, which creates squeal, at least with my experience.
Mike V. / San Diego
Re: Disc Issue
« Reply #6 on: March 17, 2012, 04:46:56 PM »
With the buffed up brake disc, Lou, I'm sure the MOT inspector will think you've done an over-the-top overhaul of the entire front brake system.
Perhaps a few quid tucked under the front tire will speed things along? Just something por los niños is what works for Victor and I. Maybe Mike V, too. ;)
EGRG
Re: Disc Issue
« Reply #7 on: March 17, 2012, 11:45:21 PM »
After NAFTA we stopped accepting quid. Dollars are the currency of choice for any serious bribery.
Re: Disc Issue
« Reply #8 on: March 18, 2012, 05:48:58 AM »
You forget this is Yorkshire where the economy is so bad we have to barter, the favoured currencys at the moment are Black Pudding or Rhubarb the Pound and Euro are way down the list although i would be alright with a few Green Backs if i had any......
Lou (banned from the garage for 24 hours.... [smiley=undecided.gif].... [smiley=kiss.gif] but shes happy)
« Last Edit: March 18, 2012, 05:49:36 AM by Lucky_Lou »
Re: Disc Issue
« Reply #9 on: March 18, 2012, 09:33:48 AM »
24 HOURS!  Lou, that's so harsh. Close to being Elder Abuse. ::)
Re: Disc Issue
« Reply #10 on: March 20, 2012, 10:59:54 AM »
Well the old Kit came in handy..and some wet and dry + elbow grease
Had no problem with the MOT i just showed him my Balls..
Now to finish the K
Re: Disc Issue
« Reply #11 on: March 20, 2012, 12:15:44 PM »
So, you've got a new Kitchen Pass from the Chief of the House that'll let you go back to the garage?
Try no to blow up anything important. ;)
