There is a small size green number at the bottom of the speedometer face, if those numbers are the same, you can swap them out, if they don't, I believe there are different size gears inside of the speedometer .
I think you would have to change the gears inside to get it to work correctly .
But, there's only one way to find out for sure, install it and see how close to being accurate it is with the bike being ridden .
