Author Topic: ´82 R65LS seat on a ´79 R65???  (Read 1351 times)
fbenach
« on: February 05, 2012, 11:42:40 AM »
Hello!!!
A question for the wizards!!
I´ve been thinking on changing my regular seat for a R65LS one with handles... something like this...
http://www.ebay.com/itm/Seat-and-cowl-BMW-1982-R65LS-/110815453251?hash=item19cd1da043&item=110815453251&pt=Motorcycles_Parts_Accessories&vxp=mtr
Anyone knows if it fits? Is there any transformation needed???
Thank you in advance!!!!
Re: ´82 R65LS seat on a ´79 R65???
« Reply #1 on: February 05, 2012, 11:53:55 AM »
I assume am LS seat would fit any 81 -84 R65. Don't know for sure if it would fit a 79 as the subframe is a different part No so maybe you would need the later subframe. The storage box that sits over the battery is also different so you would probably need that too.
« Last Edit: February 05, 2012, 11:58:35 AM by bhodgson »
wirewrkr
« Reply #2 on: February 06, 2012, 01:33:20 AM »
the only thing you will need is the storage compartments for an LS.
OR run none, then you'll be golden.
Milo_357
« Reply #3 on: February 09, 2012, 04:25:59 PM »
Can you by a seat that is LOWER to the frame than the standard seat?  The average seat is what, 4, 5" "tall"?  I'd LOVE to shave a couple inches to get my feet lower to the ground.
« Reply #4 on: February 09, 2012, 05:16:21 PM »
You can re-cover a seat and remove some of the foam to lower the seat height but there is nothing like 4 or 5" of foam. It's 2" at the most.
