Author Topic: Can't get a turn signal grounded  (Read 1534 times)
scottyintex
« on: January 27, 2012, 11:14:26 AM »
I am adding another turn signal to the sidecar...but can’t get it grounded for some reason. I ran a hot wire from another working turn signal..it snakes around the frame for about three feet. Hooked it up to the light..ran a ground wire to the frame..but it won’t work. This is just your regular BMW R65 turn signal. Thought maybe the light wasn’t working...so hooked a batter to the turn signal. It worked. I grounded the turn signal to the same bolt that I used to ground a LED running light that I added.  The turn signal and LED are grounded to a plain steel...unpainted bolt...than runs through a metal fender into the steel frame of the sidecar. The running light works fine..but the damn turn signal won’t.  So....what am I doing wrong???  >:(
« Last Edit: January 27, 2012, 11:17:18 AM by scottyintex »
Re: Can't get a turn signal grounded
« Reply #1 on: January 27, 2012, 11:39:37 AM »
I would run a separate ground wire for the directionals .
You may need a 'bonding' wire between the side car and R65 frame to connect them electrically .
All of the circuits on the R65 use individual ground wires they are all 'ganged' together at one ground or earthing point on the frame .
scottyintex
« Reply #2 on: January 27, 2012, 12:37:17 PM »
Ok, I tried moving the grounding wire to another bolt...one without the LED ground on it..still won't work. :(
« Reply #3 on: January 27, 2012, 03:00:49 PM »
Methinks Bob suggests you run a ground wire to an earthing point on the motorcycle rather than the bolt on the side hack. A flexible braided grounding strap from car to bike would be neat-o, too. Could shorten some wire runs.
scottyintex
« Reply #4 on: January 27, 2012, 07:53:38 PM »
Well, shucks all this electric jargon is too complicated for me. Giving me a bigger headache than long division did. Think I will just hang the lights where I want them and take it to Roger at on road off road and let him build a wiring harness. He has a degree in electrical engineering...think he might even under stand Algebra. For the moment red neck engineering is at a halt.....just when it was beginning to look like a Christmas tree going down the road. :o
« Reply #5 on: January 28, 2012, 09:18:03 AM »
Scotty, I think we're gonna have to ground YOU and make you stay after class. [smiley=wink.gif]
Can't be that chilly in Marble Falls. Grab the volt/ohm meter and get busy. BTW, you still owe me a Shiner Bock in Luckenbach. [smiley=beer.gif]
My personal regards to your charming and very patient wife. She's gotta be a saint. . .
jg928s4
« Reply #6 on: January 29, 2012, 12:07:43 AM »
Need a good Ground strap from Bike to the Sidecar.
