Author Topic: Wheel Bearing Removal  (Read 1280 times)
Offline Dave 2
« on: January 07, 2012, 11:19:07 AM »
I was flipping through my Clymer yesterday and read that you should not put a torch to the wheel hub to remove wheel bearings because this could cause the wheel to deform. I took my wheels to a motorcycle tire specialist/machinist to remove the tires and bearings...He used a torch to heat up the hubs.  :-X He put a lot of heat on them.  What do any of you think? Thanks D2
Re: Wheel Bearing Removal
« Reply #1 on: January 07, 2012, 11:31:16 AM »
This process is not applicable to the R65, the only thing holding the bearings in the front wheel of an LS, is a press fit, the rear wheel bearings, the outer grease seal is all that holds them in .
On some larger bikes, possibly earlier bikes it was required .
Mike V. in Sandy Eggo, had some pictures of this when he did his '78  R100 .
« Last Edit: January 07, 2012, 11:32:10 AM by Bob_Roller »
Offline Dave 2
« Reply #2 on: January 07, 2012, 12:19:56 PM »
Thank You Bob, I'm happy to hear that. D2
« Reply #3 on: January 07, 2012, 02:20:11 PM »
I've used a propane torch on the rear wheel hubs of both my R65s to aid in a more gentle removal of the outer bearing races. Not necessary to get it scorching hot; just bring it up to the finger tip test..."Jeez! Dat's hot!"
A long drift is used to access the back side of the race. It'll come out easily.
I also warm the hub and chill the new outer races before fitting into the hub. A large, matching O.D. socket is helpful in setting the new races.
Offline Dave 2
« Reply #4 on: January 08, 2012, 02:10:35 PM »
Is it OK to take advice from a Rooster with a thingy?...if so, thanks Monte. D2
Offline Adrian
  • The Old Hairy Biker Sez...
« Reply #5 on: January 09, 2012, 05:22:20 AM »
Thanks for this Bob I always thought that this was a specialist process but if its that simple (he said tongue in cheek) then I'll be doing mine myself. I was attempting a spruce up of the old girl but the more I removed the more sorry she looks so its on to plan B and do a full resto.
1984 R65 (860)
