Author Topic: Bags and Mounts for an 82 R65  (Read 1352 times)
GDeane
« on: December 09, 2011, 09:01:12 PM »
I have an 82 R65 and found a listing for an 87 R65.  Any idea if these will work?
http://denver.craigslist.org/mcy/2744428629.html
Re: Bags and Mounts for an 82 R65
« Reply #1 on: December 09, 2011, 10:14:57 PM »
You may be able to use the bags, but those mounts are for the monolever frame bikes (R65/R80/R100) that started with the 1986 model year.  They won't work on your 81-84 twinshock R65 frame.    You need to find R65/R45 specific mounts for the twinshock frame, vintage 1979 - 1984.   Actually, now that I think about it, those bags may not work with the twinshock mounting frames either - I can't tell from the pics, but they look like the bags I had on my 88 R100RT, and I think that the have a locking clasp on the front edge that is supposed to grip the frame mounts on the monolever bikes?
« Last Edit: December 09, 2011, 10:18:40 PM by nhmaf »
GDeane
« Reply #2 on: December 09, 2011, 10:53:47 PM »
Had a feeling.  The search continues.  Thanks for your reply.
Greg
« Reply #3 on: December 10, 2011, 04:47:25 AM »
That's not a bad price, though.
GDeane
« Reply #4 on: December 10, 2011, 06:50:12 PM »
Best price on a complete set I'd seen for a while.  Won't work for me, but maybe someone here with a newer model.
Red_Hen
« Reply #5 on: December 14, 2011, 04:36:11 AM »
Monte made a post about teardrop shaped soft bags that go under seat & look classy & are cheap from JC Whitney - my problem with BMW panniers for airheads is most are old & hardware is not so great.
I like the soft bags.
Dowco
http://www.jcwhitney.com/sport-bike-saddlebags/p2010256.jcwx?filterid=b932c14523u0j3#Reviews
« Last Edit: December 14, 2011, 04:41:18 AM by Red_Hen »
« Reply #6 on: December 14, 2011, 08:20:13 AM »
Dowco
Yep, I do like the Dowco soft bags. I can switch them between either R65 in just a couple minutes and I'm good to go. You can buy similar bags for more bucks -these also have the rain booties in a side pocket- but I have had zero issues with the lower priced units. I later bought the matching tank bag.
Point: The wide, adjustable, HD velcro straps (2) go over the seat and support the bag's weight. Straps attached to the rear frame diagonal members and a third strap runs around the end of the rear frame to keep everything stable.
As do most all soft bags, they will sag inward a little bit when heavily loaded but not near enough to interfere with suspension or tire.
Red_Hen
« Reply #7 on: December 14, 2011, 09:54:29 AM »
Here's mine on the R65LS - nice for carrying a sweater, camera, water.
PowerCat
« Reply #8 on: December 21, 2011, 12:03:12 PM »
Greg,
I'm sending you a personal message about some bags that I have that you might be interested in.
David (AKA PowerCat)
