Author Topic: Steering Lock on frame  (Read 798 times)
« on: November 30, 2011, 05:00:06 AM »
Hi All,
I posted a thread a while back on the above, I followed the advice re using the key etc, however, there is what appears to be a small brass coloured pin that holds the key cover in place and stops this cover from rotating completely out of the way allowing me to remove the barrel.
So, do I drill this out or is there another way to remove it?
I can re-post the image if required
Thanks
Chris
darrylri
Re: Steering Lock on frame
« Reply #1 on: November 30, 2011, 08:48:16 AM »
Gently use a screwdriver to pry the cover off.  It will take the pin with it.  It's just a press fit.
« Reply #2 on: November 30, 2011, 10:12:54 AM »
Thanks Darryl
Appreciate your help & wisdom!
