Author Topic: De-greasing  (Read 889 times)
Ron_S.
De-greasing
« on: November 01, 2011, 09:31:16 AM »
After the great advice I got about charging my battery, I have another of the many questions to come.  How do I de-grease/oil my motorcycle.  I'm told, and most automotive de-greasers warn, not to use them on motorcycles.  I'm told this is because the products will discolor the engine.  ??????
Re: De-greasing
« Reply #1 on: November 01, 2011, 09:59:40 AM »
I've been using 'Gunk' degreasing products on my R65 since I've had it .
If you get it on painted surfaces, it will spot up a bit, a good washing and wax afterwards gets rid of it .
It also works best on a warm, not hot engine .
Re: De-greasing
« Reply #2 on: November 01, 2011, 03:43:16 PM »
What this about oil and grease on a BMW engines - are you telling me they leak.  ::)
Ok I get a bit of misting from the push rod tubes. I use a spray foam alloy wheel cleaner before washing the bike. Works fine as long as the oily dirt is not allowed to build up too much.
Re: De-greasing
« Reply #3 on: November 01, 2011, 05:03:26 PM »
If I have serious staining (dark areas) I will go after it with Eagle 1 Mag Wheel Cleaner for unpainted rims as it is acidic and does a good job bleaching out the dark spots.  Do not let it dry before scrubbing/rinsing!  I usually go over any greasy/oily areas with a brush and full-strength Greased Lightning - it's a helluva good high alkaline cleaner.
Ron_S.
Re: De-greasing
« Reply #4 on: November 02, 2011, 09:04:38 AM »
Thanks again, Gentlemen.
Barry, did I imply leakage?  Heaven forbid.  I, too, get the misting from the push-rod tubes, but it just keeps my boot properly conditioned.  I just failed to mention how clumsy I am-spillage happens.
