Author Topic: What other models interchange with R65 gearbox?  (Read 975 times)
raygun
« on: June 17, 2007, 10:53:09 PM »
I'd like to know what models will interchange with the '79 R65 gearbox. I maybe looking for one.
airhead
Re: What other models interchange with R65 gearbox
« Reply #1 on: June 18, 2007, 05:56:01 AM »
You're ok there as all 5 speed box's from all models to '80 will fit. The ratios are the same, in fact I have a spare box for my 90/6 that came from a '79 R65. The models before '77 will look slightly different in that they will be smooth sided, and '78 to '80 will be ribbed, but they still fit fine.
Bill.................;-)
« Last Edit: June 18, 2007, 05:59:57 AM by airhead »
« Reply #2 on: June 18, 2007, 06:52:55 AM »
Any 5 speed, up until the lighter flywheel (1981, I think) will work.  You can put in the later one but you would also need to change the flywheel and all clutch related components as well.
