Author Topic: Article on how to rebuild Brembo Calipers  (Read 970 times)
Milo_357
« on: October 09, 2011, 10:12:53 AM »
Just an FYI for those of you doing brake work like me.
There is an article on rebuilding Brembo Calipers in the latest issue (Sept/Oct) of Motorcycle Classics.  I got my copy at Books a Millions.
Maybe someone more in the know could let us know if the article is any good or not?
Re: Article on how to rebuild Brembo Calipers
« Reply #1 on: October 09, 2011, 10:24:38 AM »
Don't have access to the article, but here's one tip, before you remove the calipers from the fork legs, loosen the two allen head bolts that hold the caliper halves together .
They can be a pain once they are off of the bike.
Only other alternative, is to clamp the caliper in a vise between two pieces of wood .
To remove the pistons, use low pressure compressed air in one of the holes, put the caliper on some old shop towels and kinda wrap it up a bit and hold it down, fluid can go every where you don't want it to .
« Last Edit: October 09, 2011, 10:25:40 AM by Bob_Roller »
Milo_357
« Reply #2 on: October 09, 2011, 12:16:46 PM »
Ha, you should have written the article.  They show the caliper in a clamp to take the caliper halves apart.  Plus they don't show the caliper wrapped in cloth when they apply the compressed air.
Excellent suggestions!  I'm glad I made a comment about it.  I'm hoping to get a 4 piston Brembo next week and want to clean it up as best I can before using it.
Dell
