Author Topic: Indicator bulbs  (Read 2437 times)
mkocal
Indicator bulbs
« on: June 14, 2007, 03:42:04 PM »
May I ask,
Does anyone have information regarding the specs for replacement bulbs for the turn signal indicator lights on the r65 ls? I am referring to the small bulbs (2) that light up the green arrows mounted in the cockpit; not the turn signals. I cannot find any order number or spec, and neither can my dealer.
Thanks in advance
MK
Re:  Indicator bulbs
« Reply #1 on: June 14, 2007, 04:42:53 PM »
I believe it's a common SAE spec 168 'wedge' type lamp, you can get them at just about any auto parts store. They come in a blister pack of two for about $1.50 US.
« Last Edit: June 14, 2007, 04:44:33 PM by Bob_Roller »
Re:  Indicator bulbs
« Reply #2 on: June 14, 2007, 08:42:31 PM »
mkocal,
If you have one, just pull it and take it to the autoparts.  They should be able to hook you up.  There should be a number printed on one side of the base.  Try to match it.  You don't want too high a wattage, as it will make your blinkers flash weird.  I don't think you have to worry about the bulb getting too hot, as it is flashing, though.
If you don't have one, ask again, and we'll see if we can't scrounge a # for you.
Re:  Indicator bulbs
« Reply #3 on: June 14, 2007, 11:22:01 PM »
I'd go with a 193 or 168 lamp. Had a lot of trouble seeing my gauges then I read Section IV here http://pweb.jps.net/~snowbum/lamps.htm
This guy is Verbose but you will walk away knowing more about your bulbs than you ever imagined existed. i can now see my instruments at night!
« Last Edit: June 14, 2007, 11:23:53 PM by MrRiden »
Re:  Indicator bulbs
« Reply #4 on: June 15, 2007, 09:19:08 PM »
Yeah, I looked through the bulb book at the local non-chain auto parts store and picked a bulb that was .w watt brighter and could really tell the difference.
