Author Topic: annoying brake squeal - please go away  (Read 3448 times)
Offline kenlodge
« on: July 11, 2011, 10:43:04 AM »
so...i recently replaced the pads, rebuilt the front caliper & M/C.
the squealing went away for a week or 2... but now it's back!
the disc seems in good condition.
the pads were purchased at Max BMW.
i scuffed the pads w/sandpaper before installation.
i took it easy on the pads for the 1st week or so, and have since done some hard braking - thanks to some jackass drivers & a bicyclist who weren't sure what red traffic lights are for.
how can i get rid of the annoying sqeeeal that i get when coming to a stop?
chamfer &/or sand the pads ? ?
1983 R65
Re: annoying brake squeal - please go away
« Reply #1 on: July 11, 2011, 11:22:16 AM »
If you can find a product called Disc Brake Quiet, made by Permatex, it works, it is a  spray on blue plastic coating that eliminates the vibration between the pad and piston .
Only  spray it on the back of the pad, it may cause the pads to stick if it gets between the pad and caliper .
Someone here also mentioned they used common rattle can auto paint on the pads with the same results .
« Reply #2 on: July 11, 2011, 11:25:44 AM »
Brake squeal is most often caused by the pads vibrating against the calipers. .You can try the "brake quiet" spray stuff available at most automotive parts stores to spray on the backs of rhe pads that may dampen things down.  Sometimes it works OK, sometimes not.   It is possible that your light usage of the pads for a week did not allow the pads to bed in well, and the may have glazed over.   I find the better way to bed in new brake pads when I replace them is to get out on a deserted back roads where I can get up to ~ 50 MPH or so and do several hard stops.  I'd take the pads off again and scuff them up again with same light sandpaper first.  Also make sure that you didn't inadvertently pick up a stone or something that is stuck in there and causing squeal or damaging things. Don't stay stopped for any length of time - accelerate back up to 50 MPH and do another hard stop, not allowing the brakes to cool off in between.
Do this 8-10 times or so. Then drive normally.   It brake pads are treated to gently they may not bed in properly.   IF this fails to improve things, try the spray stuff too.
Offline Julio A.
« Reply #3 on: July 12, 2011, 04:36:49 AM »
I put copper grease on the backside of my pads; the side which contacts the caliper pistons; They work very well.
Julio Alarcon
1981 R65
1976 R90/6
2001 R1150 GS/ADV
2015 TR650
Olliepup
« Reply #4 on: July 12, 2011, 07:19:42 AM »
What is copper grease and what is it normally used for? Is it auto stores?
Dave
« Reply #5 on: July 12, 2011, 08:15:34 AM »
Dave
Thread lubricant. Yes.   Monte
« Reply #6 on: July 12, 2011, 08:22:14 AM »
Also referred to as anti-seize compound .
Offline Mike V
  • 78 R100/7 , 81 R65
« Reply #7 on: July 12, 2011, 10:46:47 AM »
Ken,
Good advice here from nhmaf. Even some (10 or 20) 30mph to 0mph stops may do the trick.  Allow some cooling in-between burnishing and find a safe place to do the stops as he mentions.
Mike V. / San Diego
'78 R100/7 (original owner)
'81 R65 (fully restored)
RSMike
« Reply #8 on: July 12, 2011, 11:28:10 AM »
When I got my bike 8 weeks ago and started riding it the pads were REALLY noisy, I did a fluid change, checked the pads (loads of wear left), roughed them up, did a good clean, and did the copper grease on the back of the pads trick mentioned by Julio ( this last one always worked for me on previous bikes, but none screeched as bad as the R65)
I think they might have been quiet for like about 5 miles, but then the screeching came back, My next plan was to replace the pads, however more pressing things needed attention first, and gradually as I have ridden the bike more, they have become somewhat quieter , so its now more like usual noisy brakes and not the ear piercing screeching that I originally had.
Monte noticed my skinflint ways with tyres http://www.bmwr65.org/cgi-bin/yabb2/YaBB.pl?num=1310295904,  ;), so no I'm thinking I will stick with these pads for another while, they stop fine at least and have plenty of wear to go.
« Last Edit: July 12, 2011, 11:31:14 AM by RSMike »
« Reply #9 on: July 12, 2011, 02:38:05 PM »
Copper grease is real particles of copper in a high melting point grease. It's commonly available and used on brake parts for it's anti-seize properties and high temperature rating. It's been used for donkey's years as an anti squeal coating but is probably not as good as some more modern purpose made formulations. I use it because it's a good general anti-seize and I've always got some on the shelf. As well as the rear of the pads I apply the faintest smear to any part of the pad backing plate that is in sliding contact with the caliper. You don't want to get the stuff on any of the rubber parts though.
« Last Edit: July 12, 2011, 02:54:02 PM by bhodgson »
Offline steven m
« Reply #10 on: July 12, 2011, 10:09:28 PM »
My twin disc setup squeals when the brakes are applied lightly.  If I apply more pressure the squealing goes away.  I used anti-squeal on the backs of the pads and it made no difference.  I have Brembo calipers.  Does this happen with the older ATE's as well?
Steve
« Reply #11 on: July 13, 2011, 09:22:05 AM »
My '81 with ATE calipers squealed until I put the plastic coating on the pads .
The '82 LS squealed until I replaced the OEM pads with EBC FA18 pads .
« Reply #12 on: July 13, 2011, 10:04:47 AM »
I'm using EBC FA18 pads and rarely have any problem with squeal.
« Reply #13 on: July 13, 2011, 11:34:53 AM »
I put on EBC FA18 pads last year, and they are doing some talking now this year - may be time to give them a quick swipe with some sandpaper and do the bedding in thing, followed by the spray goo on the backs if that does do the trick - I don't have any spray stuff on the backs of mine yet.
Offline kenlodge
« Reply #14 on: September 26, 2011, 07:37:23 PM »
i took out the pads, scuffed them up well w/some sandpaper, put some lubricant on the backs of the pads... then gave them another break-in, doing some 50-0mph hard braking per some previous advice.  the squeal went away ...for a bit... it's always there, lurking, just waiting to be heard.  if i brake hard it seems to kill it for a while, but for "normal" braking it prefers the squeal to quiet braking.  may try some of that spray next, idk.
or just deal w/the squeal.
1983 R65
