Author Topic: Removing MC Reservoir  (Read 4268 times)
79beem
« on: September 24, 2011, 06:29:08 PM »
Having tentatively tried to remove my reservoir and being a little more wary of the instructions in my Clymer.
Any advice on how to get the bugger off?
Clymer said to "carefully pull up and rotate reservoir".
 ( clockwise/anti ? )
Mine won't budge......... I have removed all cap screws and retaining screw underneath.
Re: Removing MC Reservoir
« Reply #1 on: September 24, 2011, 06:58:01 PM »
Have you removed the twist grip yet?
« Reply #2 on: September 24, 2011, 07:20:04 PM »
If you have a plastic round reservoir master cylinder, they are bonded (glued) to the metal assembly, not meant to be removed or separated .
« Reply #3 on: September 24, 2011, 08:21:35 PM »
Oh - is that what me meant?
Yup - true.
79beem
« Reply #4 on: September 25, 2011, 06:12:02 AM »
Its a square one chaps and they apparently come off.
Just the reservoir, not the whole assembly.
Anyone taken theirs off?
If so, how?
« Reply #5 on: September 25, 2011, 09:38:30 AM »
The only thing that is holding the resevoir into the master cylinder when the screws are removed, is an o-ring on the resevoir that seals against themastercylinder .
try to rotate it side to side to see if it breaksfree .
wirewrkr
« Reply #6 on: September 25, 2011, 12:28:40 PM »
STOP!
There is a small sheetmetal screw that comes up from the bottom that must be removed first, SHeeesh youse guys are dangerous!
« Last Edit: September 25, 2011, 12:35:05 PM by wirewrkr »
« Reply #7 on: September 25, 2011, 01:04:40 PM »
Busted, forgot that one !!!!
Long time since I've had mine off (1998!!!!!) .
MR.E
« Reply #8 on: September 25, 2011, 01:45:03 PM »
Theres an o'ring under the square ones!!!!
That explains where the fluid is coming from!
Thanks
« Reply #9 on: September 25, 2011, 01:50:28 PM »
There's about a half inch (12mm) round extension from the resevoir, it fits into the inlet of the master cylinder housing, the o-ring is on the outside of it .
« Reply #10 on: September 25, 2011, 02:22:41 PM »
STOP!
Here is a great example why you need a technical manual, when you work on something like a motorcycle, the people that made postings on this subject have done the job before and completely forgot this one important fact about a 'hidden' fastener .
« Reply #11 on: September 25, 2011, 02:46:32 PM »
So the screw the OP mentioned is not the same one you all are talking about?
« Reply #12 on: September 25, 2011, 02:50:26 PM »
Yes, it is the same one, I guess wirewkr missed that in the posting .
Like I said, get a manual, people are fallible !!!!
wirewrkr
« Reply #13 on: September 26, 2011, 12:19:06 AM »
You're correct!, My bad.
I don't even have an excuse anymore, I quit drinking on September first!
[/color][/b]
Offline kenlodge
« Reply #14 on: September 26, 2011, 07:16:50 PM »
i had a bit of a time getting mine off as well--a square reservoir on my 1983 r65.   it was stuck on there pretty good--corroded.   had to keep working around and pulling/prying up.  there's a little plastic piece sticking down on the underside of the reservoir--don't break that off--you''ll want to make sure of where that is before you start rotating the reservoir on where it attached to the M/C.  then it'll hopefully come off easier
1983 R65
