Author Topic: 16mm Master Cylinder Rebuild Kit  (Read 2090 times)
Offline Mike V
  • 78 R100/7 , 81 R65
« on: September 17, 2011, 07:45:57 PM »
Anybody know of a good affordable source for a 16mm (rectangular bar mounted) Master Cylinder Rebuild Kit?
1981 R65 w/dual ATE'
-Mike V.
Mike V. / San Diego
'78 R100/7 (original owner)
'81 R65 (fully restored)
Re: 16mm Master Cylinder Rebuild Kit
« Reply #1 on: September 17, 2011, 08:24:58 PM »
£29.00, around $46, at Motobins...  Your pretty limited on where this can be purchased from.   I wonder if anybody has tried Magura for rebuild parts?
wirewrkr
« Reply #2 on: September 17, 2011, 08:54:47 PM »
Justin, why would you say he's limited?
It's $66.00 here in the states.
as a matter of fact I'll sell this one. It's brand new, in the package.
$48.00 includes the shipping to San Diego.
I'm out in Joshua Tree.
mail me at wirewrkr@gmail.com
« Last Edit: September 17, 2011, 08:56:44 PM by wirewrkr »
Offline Mike V
« Reply #3 on: September 17, 2011, 09:15:22 PM »
Thanks wirewrkr.  I'll contact you PM.
-Mike V.
Mike V. / San Diego
« Reply #4 on: September 18, 2011, 09:54:50 PM »
Any time you are tied to a specific supplier for a part your choices are extremely limited and usually expensive...
« Reply #5 on: September 19, 2011, 10:16:06 AM »
For Brembo caliper and master cylinder parts, rebuild kits and complete assemblies at competitive prices, check out Bevel Heaven... as in Ducati, or MG Cycle... as Moto Guzzi.
http://shop.bevelheaven.com/SearchResult.aspx?CategoryID=35
http://www.mgcycle.com/index.php?cPath=110&osCsid=b0b92b623eb248e0e2114be092c8a4e9
Offline Mike V
« Reply #6 on: September 19, 2011, 12:20:40 PM »
Thanks Monte,
Those are two links I'll keep in my favorites since they are new to me.  I'm assuming the M/C is an ATE' since the OEM dual disc setup is ATE' but I could find no manufacturer markings on the rectangular M/C unit except for the spool (piston-bore) size.  Maybe something new will be exposed when I get the unit cleaned-up. I found a new rebuild kit from wirewrkr, now to acquire a new reservoir o-ring.  This is a secondary extra M/C unit I'm hanging on to as a spare so I'm in no hurry to get the rebuild done.
Thanks guys for all the info and help.
-Mike V.
Mike V. / San Diego
wirewrkr
« Reply #7 on: September 19, 2011, 10:16:12 PM »
BMW master cylinders are made by MAGURA of Germany.
« Reply #8 on: September 20, 2011, 11:01:21 PM »
Do they make a round resevoir 15mm master cylinder?
My 16mm is too much.
Thanks in advance.
