Author Topic: R65LS  (Read 705 times)
cobra407
R65LS
« on: September 14, 2011, 09:21:06 PM »
Looking for help changing front fork shock oil. Do I have to remove the master cylinder to get the right fork access to add oil? thanks peter
Re: R65LS
« Reply #1 on: September 14, 2011, 10:23:40 PM »
It is still pretty tight around there, especially if you have low/short euro bars on as I have.   I personally take the black piece of plastic that goes over the instruments off and remove the bolts that hold the handlebar on to the top fork yoke plate/clamp.  I then carefully put some thick shop towels on top of the fuel tank and rest the handlebar assembly there while I take the caps off the top of the fork tubes.   It is best to not tip the master cylinder upside down in case a seal isn't perfectly sealing in the m/c unit.
