Author Topic: does anyone have a link to a wiring diagram?  (Read 1372 times)
rob650
« on: June 07, 2007, 09:18:12 AM »
Hello,
Anyone know of a link to a wiring diagram I can view?
i've been losing my taillight, running lights and instrument lights intermittently (all at the same time).
Thanks.
Jon_P
Re: does anyone have a link to a wiring diagram?
« Reply #1 on: June 07, 2007, 09:43:18 AM »
there was a thread asking the same thing a week or two ago. do a search for wire diagram and it sould pop right up.
here i looked and found it http://suraklyn.com/yabb/YaBB.pl?num=1180474659 click on the link and it will take you to the thread with a link to the diagram.
drewboid
« Reply #2 on: June 07, 2007, 11:56:58 AM »
Sounds like a loose fuse or the wires to/from it.  They are all on the same circuit.  See if there is any corrosion on the fuse clips or connectors as well.
« Reply #3 on: June 08, 2007, 11:35:55 PM »
I would check your fuses, also.  I had to replace that very fuse before it would act right.
Everything was fine until I decided to do some maintenance and clean the contacts on the fuses.
Then I sandpapered that fuse and used dialectric grease, but it just would not give me consistancy.
One day on a trip I found myself in a dealership, so I bought a couple of fuses.  I put one in, and my taillight has be working ever since!
rob650
« Reply #4 on: June 11, 2007, 11:13:08 AM »
Problem solved.  I went through all my wiring a couple of weeks ago, cleaned contacts and applied dialectric grease where I could.  I didn't reconnect the headlight connector tight enough, to that small secondary bulb.  And I finally thought to look in this location while at a rest stop in Nevada a couple of days ago.  It was one of those "Hey, I haven't checked xxxx yet!" moments while my brain was focusing on something else entirely different (lunch).
I'll keep the links to the diagrams for the future, thanks everybody.
« Reply #5 on: June 11, 2007, 10:38:45 PM »
The +12v connection to your running light was causing this? :o
That sounds weird.  Unless it was shorting to ground....maybe...
