Author Topic: Twin front disc set up  (Read 2134 times)
79beem
« on: August 23, 2011, 06:28:49 AM »
Does anyone know if a right side brembo caliper from a 1993 R80 RT  would fit a 1979 R65 right side disc?
Or any other calipers for that matter?
I currently have a later model square master cylinder ( not sure from what ) do i need a specific size to run 2 calipers?
« Last Edit: August 23, 2011, 06:31:48 AM by 79beem »
Re: Twin front disc set up
« Reply #1 on: August 23, 2011, 08:00:21 AM »
The standard size from the factory for a twin disc front brake, is  a 15 mm .
It's cast in to bottom side of the master cylinder .
79beem
« Reply #2 on: August 26, 2011, 06:03:41 PM »
Thanks Bob,
So does anyone know if any calipers from other R's would fit a right side front disc?
« Reply #3 on: August 26, 2011, 07:51:24 PM »
From what I have heard, the calipers are pretty much R65 specific .
Offline Julio A.
« Reply #4 on: August 28, 2011, 04:27:42 AM »
The R65 does not share it's caliper with other airheads.
Julio Alarcon
1981 R65
1976 R90/6
2001 R1150 GS/ADV
2015 TR650
« Reply #5 on: August 28, 2011, 07:44:57 AM »
I've noticed that my right side Brembo has a shim to reduce the mounting hole diameter. That suggests to me it's borrowed from another application.
As for the master cylinder - it's possible your single caliper model will work just fine with duals. I've used 13s and 14s for duals and they work just fine. The 12mm may be fine also, the problem being excessive lever travel. Doesn't hurt to try it out, as long as the brake clamps before squishing your fingers. :-)
« Reply #6 on: August 28, 2011, 07:57:56 AM »
That shim or spacer, is to position the caliper on the rotor .
I've got an '81 R65 with ATE calipers and it too has the spacer/shim .
79beem
« Reply #7 on: August 31, 2011, 07:42:11 AM »
Thanks chaps, the search continues..............
« Reply #8 on: September 01, 2011, 09:50:30 AM »
My spacer is on the outside - a top hat affair. I tried it on the other side between the caliper and fork, but spaced it too far out. So it definitely is a shim to reduce the hole size. It was made for an attachment with larger bolts.
