I had the whole bike apart and put back together. Bike runs and all, but I have one last issue. My right turn signal on teh dash isn't working. Or, it's working too well, depending on how you look at it.
When the key is turned the headlight comes on and so does the turn signal on the dash - BRIGHT. If I turn the key the rest of the way, the actual signals come on (I have a Kaisan signal minder). At that point the left one will come on (dimly) as it always has.
When I use the signals they work correctly, but the right dash indicator won't blink. It's just full on bright- always. There must be something I did wrong putting this all back together, but I'm not sure what. I guess I'm going to have to trace all the wiring and look and see if something is jumpered, but I was hoping someone had a guess here first.
It would make more sense if it didn't work!
