Author Topic: speedos - not the swimming kind  (Read 1846 times)
MR.E
« on: August 05, 2011, 04:00:10 PM »
Hello
I've removed the speedo from the BMW (1981 r65).
Is there a way to fit a speedo with a smaller connection screw on the back of the  unit, the BMW one seems large compared to my other bikes is there a step down you can buy?
Hope it makes sense
Re: speedos - not the swimming kind
« Reply #1 on: August 05, 2011, 04:27:48 PM »
I've never heard of one, but you could probably have a machine shop make you one - at a very high price.
Then you have to worry about conflict with all of the other cables and bracketry.
I guess you are doing away with the dash panel?
If not, will this substitute speedometer have the same display diameter to fill the hole?
Will this substitute have the correct ratio to go with your final drive?
MR.E
« Reply #2 on: August 19, 2011, 04:11:46 PM »
Hello again
managed to get a cable made & fit a smaller mechanical speedo to the bike BUT then i find out theres a ratio thing on speedos & it's why my speedos well out of sync.
SO, any ideas what an R65 ratio is or where i can find a small (60mm) mechanical speedo?
Thanks for your help
« Reply #3 on: August 19, 2011, 05:26:17 PM »
The speedo ratio printed on the face of Airhead speedos is the number of cable revolutions for 1 mile traveled and therefore the correct ratio depends on which final drive you have.
Info in this previous thread
http://www.bmwr65.org/cgi-bin/yabb2/YaBB.pl?num=1300201693/7#7
« Last Edit: August 19, 2011, 05:32:09 PM by bhodgson »
« Reply #4 on: August 19, 2011, 09:32:46 PM »
IF you're going with aftermarket speedometers, the easiest solution is to get the kind that uses a magnetic sensor pickup on the front wheel (like a bicycle).  The Vapor, and many other units work this way, and you can reprogram it to properly match the circumference of whatever front wheel/tire combo you are running
MR.E
« Reply #5 on: August 20, 2011, 02:35:31 PM »
cheers for the replies,
i fit the Vapour to my WR work really well BUT would like to keep the mechanical style to the bike.
thanks
just looking at my bmw speedo now, at the bottow of the face it says - W 1276 - is that the ratio??
« Last Edit: August 20, 2011, 02:39:39 PM by MR.E »
« Reply #6 on: August 20, 2011, 03:19:23 PM »
Yes.
It's the correct ratio for a 3.44 final drive.
MR.E
« Reply #7 on: August 20, 2011, 03:22:45 PM »
ok, i've no idea what i'm looking for do i need a 1:276 ratio speedo then??
Thanks very much
« Reply #8 on: August 20, 2011, 03:51:03 PM »
The "W1276" number means the speedometer is geared to  1276 revolutions of its input = 1 mile, and conversely, 1276 revolutions per minute = 60 MPH, though many of these BMW speedos tend to always read a bit higher, by 3%-5% on average, for the speed indication, they are generally very accurate for distance (odometer) when working properly.
Since the speedometer is inferring your road speed by the number of revolutions of the drive shaft, different final drive ratios require different speedometer ratios.   If you had a 3.56:1 final drive (32/9 stamping) you'd need a "W1318" speedo.   If you had a 3.0:1 (33/11 stamping) you'd need a "W1112" speedometer
The speedometer seller should be able to tell you the turns-per-mile or turns-per-kilometer for any unit they are selling.
Offline NorR65
