Author Topic: Anodizing  (Read 940 times)
Crossrodes
Anodizing
« on: May 04, 2011, 05:25:38 PM »
The filler on my gas tank is kinda worn looking and I'd like to get it refinished.  Has anyone here ever got that part anodized or coated it with another finish?
Re: Anodizing
« Reply #1 on: May 04, 2011, 07:16:05 PM »
Do you mean your entire gas tank?
Anodizing would require stripping it down to absolutely bare metal and would be fairly expensive for a one-off part.  Of course, hardly any paint would stick to the anodized surface afterward.
You could get new lead paint for the tank liner or other fuel tank liner product.
DgM
Re: Anodizing
« Reply #2 on: May 05, 2011, 12:16:17 AM »
Anodizing works on aluminum.  R65 tanks are steel...
Crossrodes
Re: Anodizing
« Reply #3 on: May 05, 2011, 12:35:16 AM »
I'm speaking of the filler cap.  I believe it is anodized now and I believe it is aluminum.
bruce_launceston
Re: Anodizing
« Reply #4 on: May 05, 2011, 03:56:10 AM »
I don't think they are anodised. Pretty sure it's a paint finish. K&H Matt black replicates the original finish when applied over the top of the existing coating.
Also replacing the plastic trim ring smartens them up. They are still available and less than $5.
« Last Edit: May 05, 2011, 03:57:33 AM by bruce_launceston »
Re: Anodizing
« Reply #5 on: May 05, 2011, 06:24:15 AM »
Mine certainly looks to be anodised alloy. Maybe the finish varied over the years.
How much does a new cap cost ?  Could be cheaper than having it re-anodised even if you could find someone to do it.
Here's an interesting link to DIY anodising. This guys looks to have got some good results with colors including black. He also talks about removing the original finish first. http://astro.neutral.org/anodise.shtml
« Last Edit: May 05, 2011, 06:36:28 AM by bhodgson »
