Author Topic: timing chains  (Read 903 times)
dbub
timing chains
« on: June 01, 2007, 07:11:47 PM »
how long should a timing chain last?
Re: timing chains
« Reply #1 on: June 01, 2007, 07:46:24 PM »
I've always considered that a question kind of like, "how long should a man's legs be?"
Answer - long enough to reach from his hips to his feet..   Depending on how the
engine was treated: infrequent/never oil/filter changes, high temperature or very dirty/dusty
environments, lots of revving/drag racing behavior, and how good the chain tensioning
mechanism is can all play into it.     I've seen some severely abused engines need a
new timing chain with only 40-50K (miles) on them, others have gone 200K (miles) and
still been within operating spec.
And sometimes, though it is fairly rare, they can just wear prematurely due to
a manufacturing defect or assembly error at the factory relating to  the chain
itself, or one of the components it interacts with (timing gears, tensioner block,
cam, etc)
Re: timing chains
« Reply #2 on: June 01, 2007, 10:08:18 PM »
After 78k miles the one in my '81 R100 was getting a bit noisey and had stretched noticeably.  The cam sprocket still looked great but I probably should have replaced the crank sprocket as the teeth were pretty worn - it will definately need one with the next chain...
