Author Topic: Fuse panel  (Read 1590 times)
Roger_Lucas
Fuse panel
« on: April 16, 2011, 12:33:09 PM »
Seeing how I got the bike all ripped apart, I was looking at the outdated fuse panel & the corrision around it.
Anyone ever used a Cen Tech panel to replace it with? Or something else?
I'm in the process of updating the whole electrical system, & this looks like a possible weak link..Ya think???
Re: Fuse panel
« Reply #1 on: April 16, 2011, 12:49:29 PM »
Those fuses can cause a lot of unnecessary problems, just about anything would be an improvement over the original .
Re: Fuse panel
« Reply #2 on: April 16, 2011, 02:16:39 PM »
Save some money and buy a few more gallons of that expensive Obama-line... Stop by your local NAPA and pick up a couple of waterproof fuse holders that accept the "mini size" blade fuses. Ditch the crappy euro-style corrosion factories and ride happy.
benlawlor85
Re: Fuse panel
« Reply #3 on: April 16, 2011, 04:22:02 PM »
Hi,
I used a standard 4way fuse board so i have two spare ways one for my dash mounted power socket and one for the future! lol
pics on
http://www.facebook.com/album.php?fbid=194746553882987&id=100000429314611&aid=47322&l=a2cc916f0d
the nice this is that it requires no cutting of the loom etc really is a 2min job.
Roger_Lucas
Re: Fuse panel
« Reply #4 on: April 17, 2011, 05:52:02 PM »
Monte, Used your way of fixing the fuse panel...old one now resides in the trash! ;D
Re: Fuse panel
« Reply #5 on: April 18, 2011, 08:55:21 AM »
The fuse 4 slot sounds like something I may do! Thanks.
And Monte what is an adel clamp?
Re: Fuse panel
« Reply #6 on: April 18, 2011, 12:34:43 PM »
...Monte what is an adel clamp?
The "Adel" clamp is more properly called an MS21919. It's a loop-type, cushioned (usually) aluminum alloy aircraft clamp. The cushion assures a snug fit and eliminates vibration, thus preventing line abrasion along runs of fuel, hydraulic, electrical, etc.
Company named Adel built a zillion of the MS21919 clamps back in the 60's -they may still. The term sort of stuck even though they are now made by dozens of other companies.
I have a large selection left over from my aircraft addiction days. They find their way into many of my projects.
Thanks, Sue. That was a good question. [smiley=thumbup.gif]
Re: Fuse panel
« Reply #7 on: April 19, 2011, 09:56:26 PM »
Or, you can do like I did and forego the fancy aircraft clamps and just use zip ties on the wires, and then ziptie them to a spare screw hole on the relay mounting panel.
Re: Fuse panel
« Reply #8 on: April 20, 2011, 05:15:32 AM »
Uh Huh... Note the zip tie in my second photo.   Monte
Crossrodes
Re: Fuse panel
« Reply #9 on: April 20, 2011, 08:46:54 AM »
Electrical Connection sells electrical components for motorcycles.  Here's a fuse panel they have:
http://www.electricalconnection.com/images/pplate-gl15-installed.jpg
Re: Fuse panel
« Reply #10 on: April 20, 2011, 09:36:27 AM »
Speaking of zip-ties...Derek has some that have an integral hole tab just for the purpose of attaching the tie to a bolt. Neat! Not all of them do.
BTW Derek knows that Adel clamp then as a "P" clamp. Maybe because of it's shape? ;) ::)
Different names for things is always interesting. Those steel slotted 'universal' clamps that ya use a screwdriver or hex socket to slowly tighten say around a hose connection, we call Jubilee clamps. The inventors name is often used by some...like Kleenex!
Re: Fuse panel
« Reply #11 on: April 20, 2011, 06:51:41 PM »
There ya go, Sue. You get it!   Monte
