Author Topic: Tappet clearance  (Read 1021 times)
Tappet clearance
« on: April 02, 2011, 11:17:46 AM »
While helping a friend adjust his valves, he pulled out the small owners manual which listed clearance at .002" and .008".
I'd never seen that before and as far as I knew, all beemers were set at .004 and .008. We set them at .004, but now I'm wondering.
I've done a little searching and can't find anywhere else that lists the intakes at .002".
What's going on here? Any of you have more data?
Re: Tappet clearance
« Reply #1 on: April 02, 2011, 11:36:55 AM »
That was the recommended clearance value from BMW back when the bikes first came out .
I think  most owners set the intake to .004 in these days .
« Reply #2 on: April 02, 2011, 02:32:35 PM »
BMW recommended valve clearance changed a few times when the bikes were new. This is the history as far as I have seen in print. The service bulletin superseded the original owners manual when clearances were found to be closing up.
78 - 80 owners manual   inlet .004"    Ex .006"
81 -      owners manual   inlet  .002"    Ex .008"
Mar 82 Service bulletin   inlet .004"    Ex .008"
« Last Edit: April 02, 2011, 02:39:45 PM by bhodgson »
« Reply #3 on: April 04, 2011, 09:33:52 PM »
Thanks! That's exactly what I needed.
