Author Topic: Optimum master cylinder size for twin disks?  (Read 3839 times)
zebedee
« on: March 10, 2011, 08:06:38 AM »
I've got a 1984 late twin shock R65 with factory single disk which I'v had since 1987/4000km.
Over the years I've picked up a second disk and now a right side caliper. The current 12mm master cylinder has internal corrosion (despite having been stainless steel sleeved in about 1995), so now is the time to change to twin disks.
I believe the factory master cylinder for the R65LS or R65 with optional second disk was 15mm, but other sizes are also available. Has anyone tried a 14mm master cylinder?
The factory plumbing seems to have involved a T up near the headlight and two brake lines. Is there any reason I can't put a short line from the bleed port on the left caliper into the right caliper, and bleed at the right caliper?
Graham in Oz
Re: Optimum master cylinder size for twin disks?
« Reply #1 on: March 10, 2011, 08:36:35 AM »
You can route the line for the right caliper from the left caliper .
You just need a longer 'banjo' or hollow bolt and an extra crush washer .
My bike came with twin front discs from the factory and had a 15mm master cylinder .
The 14mm master, will  have a longer travel to provide the same fluid displacement as a larger bore cylinder, don't know if that will cause any problems in real life use or not .
Offline Julio A.
« Reply #2 on: March 10, 2011, 08:54:53 AM »
How could you tell the displacement of the master cylinder?
I really don't know what size is on mine.
Julio Alarcon
1981 R65
1976 R90/6
2001 R1150 GS/ADV
2015 TR650
« Reply #3 on: March 10, 2011, 09:58:24 AM »
Julio the size should be stamped into the casting under the reservoir
My 79 twin disc is 16mm Brembo master cylinder with twin ATE calipers.
There is a brass splitter block under the headlight you can see it in this pre rebuild photo .
Pretty good braking really
Motorworks part number
BRA 02355
« Last Edit: March 10, 2011, 10:04:42 AM by Lucky_Lou »
zebedee
« Reply #4 on: March 10, 2011, 10:03:45 AM »
The bore in mm is cast into the underside of the master cylinder. As far as I can tell the options are 12, 14 and 15, though Lucky_Lou says he's got a 16. I've got a bare 15 somewhere here, but no innards. I might see if it can be sleeved down to 14, otherwise put a new 15mm piston and seal kit in it.
zebedee
« Reply #5 on: March 10, 2011, 10:07:57 AM »
There is no banjo fitting at the caliper on my bike, the brake hose fits straight into a threaded hole in the caliper.
The hose and the bleeder are both the same thread.
Before I replaced the rubber hose with a steel braided one, I had a little trouble with excessive lever travel with a 12 and one disk. As I said above, I've realised I have a bare 15mm casting, so I guess thats getting built up.
bruce_launceston
« Reply #6 on: March 10, 2011, 04:48:01 PM »
Stick with a 15 mm bore, the standard R65LS twin disk setup has good feel.
The standard brass splitter fitting behind your headlight should have plenty of blanked off outlets where you can run a separate left and right hose from.
I have twin disks and there is still a blank spare, I guess it is for a older style front brake light switch.
If you buy a new hose set, mine is a HEL set, you can get rid of a lot of clutter from the lower fork leg as the hoses go straight to the brake calipers. This set utilises the existing splitter behind the headlight.
« Last Edit: March 10, 2011, 04:49:48 PM by bruce_launceston »
« Reply #7 on: March 10, 2011, 06:30:11 PM »
Here is the splitter:
And here it is, mounted:
« Reply #8 on: March 10, 2011, 07:12:33 PM »
I was going to suggest trying the 14mm if you like a bit more travel and "feel" in your front brake.  My LS has the 15mm m/c with twin Brembos and it goes from nothing to full lock in very short distance.
I'm used to it, but not everyone cares for such rapid/abrupt braking.
Offline Julio A.
« Reply #9 on: March 25, 2011, 09:53:19 AM »
Mind I ask, I checked the Master cylinder on mine and at has the number 16 stamped under it. But I only have a single disk.
Does this mean My R65 has originally two disks on it before?
Julio Alarcon
1981 R65
1976 R90/6
2001 R1150 GS/ADV
2015 TR650
« Reply #10 on: March 25, 2011, 10:20:54 AM »
It either means your bike had  two discs or the master cylinder has been replaced at some point with one from a twin disc bike.
You must need strong hands to make that brake work I wouldn't have thought it feels very safe. For a single disc the stock master cylinder should be 13mm for the 78 - 80 bikes and 12mm for the 81 - 85.  I'd go for the 12mm unless you are thinking about fitting twin discs.
« Last Edit: March 25, 2011, 10:32:08 AM by bhodgson »
DgM
« Reply #11 on: March 26, 2011, 01:24:48 PM »
I twin disc'ed my 1983 R65.  For complete peace of mind have both calipers rebuilt, source caliper spacers - there are at least three sizes, use correct, return rest - put on NEW 15mm Master Cylinder, source factory splitter, install NEW hoses  - SS cool, ATE factory fine, enjoy another 20 years+ with no braking issues save for pad replacement.  Twin discs provide enough stopping power to pull a stoppie, though as a BMW R65 rider you would never resort to such nonsense.  Of course...
