Author Topic: Copper head gaskets  (Read 1204 times)
Offline John M
Copper head gaskets
« on: March 07, 2011, 08:33:30 PM »
I am considering using copper head  gaskets when buttoning up my rebuilt top end for the boost in compression ( supposedly a 1/2 point which would put the bike around 9.2 to 1. Any experience or cautionary notes would be appreciated.    Best regards John
Re: Copper head gaskets
« Reply #1 on: March 07, 2011, 09:53:35 PM »
This is all I found on Boxerworks.  There was quite a discussion about them a year or two ago, but that history is lost for the time being.
[size=14]by John Falconer » Sat Oct 30, 2010 5:25 pm
I haven't used theirs [San Jose BMW] but wouldn't be surprised to learn that they source them from the same place I did purchase a set from. I had a particular need for a specific thickness at the time and used them until I could finish matching up a preferred set of parts and machining.
They work ... but they also leave the motor with less oil-tightness - they don't dribble, but they ooze; and this after carefully anealing and using the Copper-Kote like recommended sealing goop.
So ... my personal opinion - stick with the stock head gaskets and get the clearances you really need/want by proper machining.
[/size]
http://www.boxerworks.com/forum2/viewtopic.php?f=1&t=823&p=9864&hilit=copper+head+gaskets#p9864
I don't know where you plan to get yours.  It doesn't look like SJ even sells them for the R65.
http://www.sjbmw.com/parts.asp#src=copper
« Last Edit: March 07, 2011, 09:54:22 PM by Rob_Valdez_79_R65 »
Offline John M
« Reply #2 on: March 08, 2011, 05:23:43 AM »
Thanks Rob , anyone else with personal experience ?
« Reply #3 on: March 08, 2011, 06:19:19 AM »
Only that I need 98 RON fuel at 9.2:1.  95 RON will ping some unless I retard the ignition by 2 deg and even then it's borderline.
I don't know how the increase in compression will impact on your later engine as cam timing may be different and that has a big impact on the "effective compression ratio"
« Reply #4 on: March 08, 2011, 07:05:39 AM »
I installed them on my '81 about 13 years ago .
You need to put some sort of head gasket sealant on them before installation, or they will leak/seep oil, especially around the push rod openings .
Also you need to anneal the gaskets every time you remove the heads .
I haven't noticed any change in engine performance and I still use regular grade fuel during the cooler months, which is 87 octane here in the US, but I need to use mid-grade fuel (89 octane) during the 'hot season'.
« Reply #5 on: March 08, 2011, 01:42:26 PM »
Many moons ago i put some on my old Beezer C15 didnt improve performance but did increase my oil consumption .....which was pretty high to start with.
Offline John M
« Reply #6 on: March 08, 2011, 02:18:21 PM »
Easy choice, no copper head gaskets. Thanks to everyone for their input.
R65_Mark
« Reply #7 on: March 16, 2011, 09:19:33 PM »
Just a note to remember that octane is often quoted using different measurement systems in different parts of the world.
For example, “petrol” in the UK/Europe is sold using a RON (Research Octane Number) measure of octane that Barry uses above, while “gasoline” in the US/Canada is sold using an average of the RON and the MON (Motor Octane Number).  Bob Roller above is using (RON+MON)/2.  RON is a typically 8 to 10 numerical points higher than MON, therefore the average (RON+MON)/2 is 4 to 5 numerical points higher than MON.
There’s lots of reasons why one system of measurement might be preferred over another, but the difference between the typical UK/Europe and US/Canada methods of presentation means that the typical US/Canada 87 octane “regular” gasoline is equivalent to between 91 and 92-octane in the UK/Europe.  In much of the UK/Europe, “regular” petrol is 95-octane, which is about the same as “mid-grade” 90ish-octane gasoline in the US/Canada.
Mark
« Last Edit: March 16, 2011, 09:23:48 PM by R65_Mark »
DgM
« Reply #8 on: March 17, 2011, 12:36:44 AM »
Check this site out for fuel that will stop pinging.  Of course this information is for discussion only and not endorsed for on road usage...
http://www.gnttype.org/techarea/misc/octanebooster.html
