Author Topic: Crankcase breather hose  (Read 5637 times)
Offline Julio A.
« on: February 12, 2011, 06:36:05 AM »
I get oil my the shifter pad on my boots every time I ride the R65. Oil is coming from the tube that connects the carburetor to the air box. Isn't the tubes supposed to be airtight? Why does oil come out from there?
Can I at least directly route the crankcase breather hose so that it would expel oil out of the bike? I do think that since it is originally connected to the air intake, oil vapors gets sucked right out.
Julio Alarcon
1981 R65
1976 R90/6
2001 R1150 GS/ADV
2015 TR650
Re: Crankcase breather hose
« Reply #1 on: February 12, 2011, 07:10:07 AM »
It's not uncommon to get oil from the left side of the intake and carb .
Not quite sure why the left side seems to do it more than the right .
The breather hoses connect to the rubber air horns in the air box on the '81 model year and later bikes .
Some members here run the oil level lower than full on the dipstick, that seems to help .
Rob Valdez has installed a hose and filter to the breather and it doesn't go through the intake system .
I don't get the drops of oil on the garage floor anymore and the accumulation of oil in the bottom of the air box is greatly reduced .
I tried a method that I read about in the Airheads Beemer Club monthly newsletter about 12 years ago .
All it required you to do, was to remove the crankcase breather housing and put a small portion of a coarse copper pot scrub pad in the housing .
The theory was that there is a lot of atomized oil in the air coming out of the breather, the pad gives it something to collect on and get returned to the oil sump .
« Last Edit: February 12, 2011, 07:40:52 PM by Bob_Roller »
« Reply #2 on: February 12, 2011, 01:55:29 PM »
Is the breather valve working properly? could be sticking open.
« Reply #3 on: February 12, 2011, 04:32:53 PM »
Bob's is a very good solution if you want to keep a stock appearance without a lot of extra work and expense.
With any solution, keep the oil level at the halfway point between the marks on the dipstick.
That is where I fill mine to when I perform an oil change.
Here are some pictures showing what I did: http://www.pbase.com/tomfarr/crankcase_breather
Offline Julio A.
« Reply #4 on: February 13, 2011, 12:54:06 AM »
Sorry for the ignorance, but what does the breather valve look like and where is it located?  ;D
I did fill oil only halfway to prevent this from happening, I'll look into the valve and put some pot scrubber on the breather housing while i'm in there.
Isn't there any chance of the pot scrubber getting sucked in?  :D
« Last Edit: February 13, 2011, 12:54:43 AM by JAlarcon »
Julio Alarcon
1981 R65
1976 R90/6
2001 R1150 GS/ADV
2015 TR650
« Reply #5 on: February 13, 2011, 02:45:08 AM »
You need to remove the airbox, and the starter cover, to get to it.
It is located at the right-rear corner of the crankcase, on top, by the starter motor.
click for really large
You have to remove the two socket-head screws on either side of it, and then pull off the lid.
Or maybe you just stuff the pot-scrubber material down the hole after removing the rubber hose?
Bob Roller will have the answer to that.
If you remove the cover, there is a good chance you will need to replace the paper gasket, because you might tear it in the removal.
« Last Edit: February 13, 2011, 03:12:45 AM by Rob_Valdez_79_R65 »
« Reply #6 on: February 13, 2011, 04:04:53 AM »
Another picture of the breather location taken from the RH side of the engine with the domed breather cover removed. This is the early disk type breather. You may have the later reed type but the location is the same.
« Last Edit: February 13, 2011, 04:18:30 AM by bhodgson »
« Reply #7 on: February 13, 2011, 04:39:35 AM »
Can you get the starter cover off without disturbing the [clamshell-type] airbox?  I've never tried, before.
« Reply #8 on: February 13, 2011, 05:44:05 AM »
Yes - It's perhaps not the way its supposed to be done but that's how I did it in the picture. Saves disturbing the choke lever and struggling with those breather hoses which are a tight fit in the air filter covers. Obviously tank has to come off and can't remember if I had to remove one or both of the ignition coils to provide some clearance.
« Last Edit: February 13, 2011, 05:45:11 AM by bhodgson »
« Reply #9 on: February 13, 2011, 08:17:49 AM »
The small, convoluted breather hose often cracks with age and can be a contributing factor to unwanted oil drips n' mess.
The replacement part from BMW is outrageously priced -leading many airhead owners owners to employ RTV sealant as a stop gap measure. Motobins has a repop hose for coffee money... that is, if you daily imbibe in the $5.00 frappuccino at Starbucks.
Offline Julio A.
« Reply #10 on: February 13, 2011, 08:57:35 AM »
My Breather hose is already in a very poor state. I just can't replace it since it has this unusual bend that I just can't seem to replicate with any kind of fuel hose.
The poor state of my breather hose does explain the collection of oil around the airbox and starter cover.
Julio Alarcon
1981 R65
1976 R90/6
2001 R1150 GS/ADV
2015 TR650
« Reply #11 on: February 13, 2011, 10:32:02 AM »
The breather hose is available from BMW, like you stated, you can't get a fuel or heater hose to fit and make the bends it needs to .
If you need the part number for the OEM hose, just say so, as the picture in the parts catalog is very misleading .
Offline Julio A.
« Reply #12 on: February 14, 2011, 05:21:06 AM »
Oh yes please. I'd appreciate the part number very much. I think that could be the only part I could afford to buy brand new from a BMW source.  ;D
Julio Alarcon
1981 R65
1976 R90/6
2001 R1150 GS/ADV
2015 TR650
Offline Julio A.
« Reply #13 on: February 14, 2011, 09:11:05 AM »
I tried to look for the part in realoem.com but to no avail.
Instead, I found this part.
Any one knows what it is? Parts 5 and 6.
Julio Alarcon
1981 R65
1976 R90/6
2001 R1150 GS/ADV
2015 TR650
« Reply #14 on: February 14, 2011, 10:13:37 AM »
You're looking at the Air Injection system created by BMW to meet the California Air Resource Board (CARB) requirements. Had to do it to sell scoots to the poor folks in California ;)
These systems on my '81 and '83 R65s are now somewhere in the local landfill. Perfect place to reside.
Believe it's #10 that you're interested in? Motobins has them,
http://www.realoem.com/bmw/showparts.do?model=0364&mospid=51897&btnr=11_1712&hg=11&fg=10
« Last Edit: February 14, 2011, 10:13:58 AM by montmil »
