Author Topic: Brembo Caliper  (Read 3898 times)
Offline Julio A.
Brembo Caliper
« on: February 06, 2011, 07:36:13 AM »
Compared to the ATE calipers, is the Italian brand better?
I found an R65 compatible Brembo Caliper, although it is still a left side one, I'm planning to replace my current ATE ones so I could use my dad's hoarded supply of Brembo Brake pads for his past K100. The Caliper I got looks like it's going to need an overhaul; Pistons might be seized and lying on the cabinet for some decades did not really do it a favor, I already took it to a brake specialization center for overhaul.
Julio Alarcon
1981 R65
1976 R90/6
2001 R1150 GS/ADV
2015 TR650
Re: Brembo Caliper
« Reply #1 on: February 06, 2011, 08:02:55 AM »
I don't know what a Brembo caliper from  K100 looks like, so I can't say, for sure.
But the ATE, and the Brembo caliper that replaced it on the R65 series through 1984 are virtually identical.
Whether the pads from the K bike will work, you will just need to measure them, and see if they fit.
Offline Julio A.
Re: Brembo Caliper
« Reply #2 on: February 07, 2011, 05:47:33 AM »
The Calipers from a Early K100 bike is identical to the Brembo made ones for the R65; With the exception of the threaded mounting hole. The pads are the same; they are identical.
I'm just curious on whether there is an improvement over the ATE made system.
« Last Edit: February 07, 2011, 06:10:20 AM by JAlarcon »
Julio Alarcon
1981 R65
1976 R90/6
2001 R1150 GS/ADV
2015 TR650
Re: Brembo Caliper
« Reply #3 on: February 07, 2011, 09:22:23 AM »
yes becareful...not all brembos are the same.  I have moded the Brembo pads to fit in the ATE calipers.  You just need to cut a square notch in the top of the backing plate so that the spring has a place to rest -- The width of the ATE spring at about 4-5mm deep.  About 30 minutes with a dremel tool I think.
The paded surface will be about 0.5 mm higher than the ATE pad but this is still on the R65 rotor.  I changed them so I could get Kevlar pads on my ATE calipers.
Of course now I have a entire 1988 K100 front end on my R65 making it the best handling R65 in the world!  I'm not kidding.
Good luck.
Re: Brembo Caliper
« Reply #4 on: February 07, 2011, 11:27:40 AM »
What about that other guy that put a K100 fork on his R65?
(I am kidding! :) )
« Last Edit: February 07, 2011, 11:28:15 AM by Rob_Valdez_79_R65 »
larstorders
Re: Brembo Caliper
« Reply #5 on: February 07, 2011, 12:43:19 PM »
I believe the ATE , Brembo look-alikes had chrome plated pistons, and associated risk of this chrome flaking off.
Re: Brembo Caliper
« Reply #6 on: February 07, 2011, 01:02:59 PM »
(I am kidding! :) )
I missed it.  Who was it?  I thought I was the only one!  You wouldn't believe how much better it handles...
Really!  8-)
Re: Brembo Caliper
« Reply #7 on: February 07, 2011, 04:30:55 PM »
Now Bill - I said I was kidding.  (I said so, even put up a smiley face.)
Not that it has not been done to another R65, but yours is the only one I have heard of.
Re: Brembo Caliper
« Reply #8 on: February 08, 2011, 07:16:13 AM »
No worries.  If there is anybody else that has done the Best Farkel Of All Time I would love to know.   [smiley=bmw_smiley.gif]8-)
DgM
Re: Brembo Caliper
« Reply #9 on: February 08, 2011, 09:57:48 AM »
Brembos look better, both work very well.  Sent Brembo calipers from 1983 R65 to a renowned automotive brake restorer, received telephone call from restorer, delighted - Brembos are equal to automotive six pots in quality, have one third the pistons.  ATE's on 300D never a problem.
Re: Brembo Caliper
« Reply #10 on: February 08, 2011, 07:05:43 PM »
And looks are totally subjective.
DgM
Re: Brembo Caliper
« Reply #11 on: February 08, 2011, 11:05:32 PM »
If you think so.
Re: Brembo Caliper
« Reply #12 on: February 09, 2011, 07:31:20 AM »
moo...
Offline Julio A.
Re: Brembo Caliper
« Reply #13 on: February 09, 2011, 08:43:06 AM »
How does the K100 front end improve handling?
BTW, the Brembo calipers needed new piston seals. Took some time to find those in the bottomless parts cabinet. Never knew I even had those.  ::)
Julio Alarcon
1981 R65
1976 R90/6
2001 R1150 GS/ADV
2015 TR650
Teo
Re: Brembo Caliper
« Reply #14 on: February 09, 2011, 07:13:43 PM »
ATE stainless replacement pistons are (or were) available from Motobins.  Everything I saw indicated that the difference between Brembos and ATEs was related to the outer piston seal.  The ATE's have more overlap so that a large steel circlip can secure the outer seal but the bores appear to be the same.
SS pistons weren't cheap but when it comes to the baby ... I mean, come on!!!  Whats $45 or so apiece.  But, alas, it appears they are no more on the motobins website.  You might query them for availability.
Teo
