Author Topic: Generator Light  (Read 825 times)
Tony_T
Generator Light
« on: February 06, 2011, 03:13:54 AM »
When I first started my R65 after it had been sitting for 10 years, the generator light stayed on up until it reached about 1600rpm.
The generator brushes looked quite worn, so I replaced them but it still  does the same.
Is this normal?
Thanks again for your words of wisdom.......  ;)
Edit: The battery is brand new and I've double checked all connections.
« Last Edit: February 06, 2011, 03:14:35 AM by Tony_T »
Re: Generator Light
« Reply #1 on: February 06, 2011, 04:09:15 AM »
My experience is that it is not normal with a fully charged battery and no electrical load which in my case means no lights on. My generator light is off at a normal warm idle speed of 1000 -1050 rpm. With US style full time headlights I suspect the revs would need to be a little higher.
Re: Generator Light
« Reply #2 on: February 06, 2011, 09:05:24 AM »
That's pretty much normal for my bike to have the GEN light on until the engine rpm's get to the 14-1500 rpm area after the first start of the day .
