Author Topic: Slime to stop a slow air leak in a tube????  (Read 3413 times)
Vegasrandall
Re: Slime to stop a slow air leak in a tube????
« Reply #15 on: January 31, 2011, 06:16:38 PM »
I use the valve caps that are used on my employers 737 aircraft, they are brass, with a recess in the rubber seal inside for the valve stem pin to rest in and not have a chance of depressing the pin .
SW airlines?  I think I saw one landing here in vegas with a flat tire today.
« Last Edit: January 31, 2011, 06:18:14 PM by Vegasrandall »
« Reply #16 on: February 01, 2011, 07:07:24 AM »
Yeah, SW, every time you change a tire, you have to loosen the valve core to deflate the tire, so you can't put the valve cap back on .
End result, you get a tool box full of the caps after a while .
So I've got them on all of the vehicles .
scottyintex
« Reply #17 on: February 05, 2011, 03:05:55 PM »
Well, thanks Bob.........guys....turned out it was the valve cap. My valve cap that shows red if the pressure drops below 32 psi. Replace the valve cap......problem solved. They do make a green slime just for tubes but glad I didn’t have to use it.
