Author Topic: Steering Damper  (Read 2155 times)
Offline Julio A.
Steering Damper
« on: February 04, 2011, 06:15:59 AM »
Anyone has experience having this installed?
I saw one installed on a jap bike. Looks interesting.
Seeing that the R65 can be installed with one based on the microfiche, looks like it's something worth looking at.
« Last Edit: February 04, 2011, 06:48:22 AM by JAlarcon »
Julio Alarcon
1981 R65
1976 R90/6
2001 R1150 GS/ADV
2015 TR650
Re: Steering Damper
« Reply #1 on: February 04, 2011, 11:55:22 AM »
I remember seeing them as options.  Is there a problem that you are trying to fix?
bruce_launceston
Re: Steering Damper
« Reply #2 on: February 04, 2011, 04:26:29 PM »
IMO, on the R65, any symptoms that a steering damper could minimise would probably dissappear with good steering head bearing maintenance/adjustment and good front tyre selection and correct air pressures?
« Last Edit: February 04, 2011, 04:26:56 PM by bruce_launceston »
Re: Steering Damper
« Reply #3 on: February 04, 2011, 04:30:54 PM »
Exactly right [smiley=thumbsup.gif]
Re: Steering Damper
« Reply #4 on: February 04, 2011, 05:25:27 PM »
Agree with you all, (thanks to knowing Duane Ausherman).  Unless you are racing, or hauling a sidecar, a steering damper is just hiding something that should be fixed.
Offline Julio A.
Re: Steering Damper
« Reply #5 on: February 04, 2011, 11:24:23 PM »
Nothing wrong with the bike, its just the horrid road conditions here in the philipines. It's beggining to annoy me.
Julio Alarcon
1981 R65
1976 R90/6
2001 R1150 GS/ADV
2015 TR650
Re: Steering Damper
« Reply #6 on: February 05, 2011, 01:16:18 AM »
OK, you have me there!  That might be a good reason.
Chicago BMW lists the damper as NLA OBS (obsolete), which usually means unavailable.
I suppose you could rig up something.  It seems to me I saw someone here had done it, but I don't remember, for sure.
Motobins doesn't have it, either.
« Last Edit: February 05, 2011, 01:19:55 AM by Rob_Valdez_79_R65 »
Offline Julio A.
Re: Steering Damper
« Reply #7 on: February 05, 2011, 02:21:57 AM »
Actually, Aftermarket dampers are as common as side mirrors here.
Its just that there are too much different designs and brands available to the point that I don't know what to type to use.  :P
Julio Alarcon
1981 R65
1976 R90/6
2001 R1150 GS/ADV
2015 TR650
Re: Steering Damper
« Reply #8 on: February 05, 2011, 03:44:17 AM »
Well, if they are not too expensive, you may need to try 2 or 3.  Hopefully not.
Are they all adjustable?  They should be, I would think.
