Author Topic: r65 fork gaiters  (Read 4513 times)
79beem
r65 fork gaiters
« on: December 18, 2010, 08:25:00 PM »
Does anyone  know where to find fork gaiters for a 79 r65 ?
And if so whats the procedure for fitting?
I'm in Brisbane Australia.
I'm new to the airhead and motorcycling world. [smiley=bmw_smiley.gif]
Re: r65 fork gaiters
« Reply #1 on: December 18, 2010, 09:08:05 PM »
They are OEM BMW parts, you need the 13 rib gaiters fro an R65 the 11 rib ones won't work .
To install them, you need to remove both forks from the bike .
79beem
« Reply #2 on: December 18, 2010, 09:32:48 PM »
Thanks Bob,
Do you happen to the part number?
79beem
« Reply #3 on: December 19, 2010, 05:24:11 AM »
Hi again bob,
Only gaiters / boots i could find on RealOEM.com where for 87 r65GS model and onwards.
Below is a list of parts and numbers, do you or anyone else know if these are compatable with the 79 r65? The fork slider look different to me?????
Does this matter?
Regards Ian
 01 Hose clamp L=47-54MM 4   07129952121 $1.42
02 Ring  2   31421241669 $6.97
03 Rubber boot  2   31421241666 $16.90
04 Hose clamp  1   34321242268 $3.96
« Reply #4 on: December 19, 2010, 07:25:47 AM »
This is one receipt for parts that I misplaced .
I got the gaiters from a dealer on the east coast of the US .
Bob's BMW   http://bobsbmw.com/ .
Currently their parts section isn't available to me, I'll keep trying later today .
I know another member here, Rob Valdez, has them on his bike, I don't know if he has a part number available or not .
« Reply #5 on: December 19, 2010, 07:58:18 AM »
Some Beemer guys shop the truck sites for Rancho gaiters. Lots of bling-y colors to choose from. Measure the diameters of the lower slider attach point and the fork leg -36mm IIRC- then go do your shopping.
« Reply #6 on: December 19, 2010, 01:16:43 PM »
I finally got onto the website, but the part number they have for the gaiters is their own number, the boots are now aftermarket and don't have a BMW part number .
79beem
« Reply #7 on: December 19, 2010, 05:42:45 PM »
Thanks Bob and Monte for your replys and Bob your efforts.
Much appreciated.
I have sent an enquiry and parts list off to a couple of Bm shops in Brisbane, waiting for a reply.
I'll try and contact Rob Valdez if i get no joy from them.
Monte excuse my ignorance but what  does 11rc mean in reference to fork diameter???
Thanks again guys for your help
Regards Ian
« Reply #8 on: December 19, 2010, 05:42:43 PM »
I just installed the 11 rib gaiters on the R90.  Got 'em from Hucky's BMW and he also lists the 13 ribbers on his parts list.  It's not a particularly difficult task but you do have to drop the fork tubes out of the triple clamp so that may mean removing the headlight, binnacle, and such.  I have found Hans to be straight up and honest and very quick to ship.  Go to bmwhucky.com.
Oh and in case he can't recall because he does get quite forgetful in his dotage, when Monte uses IIRC he means "if I remember correctly" but that's pretty much a crapshoot with the old coot. [smiley=shoot.gif]
« Last Edit: December 19, 2010, 05:45:30 PM by Bengt_Phorqs »
« Reply #9 on: December 19, 2010, 06:10:36 PM »
Here's a page from Hucky's BMW, it's got the 13 rib boot and BMW part number .
http://bmwhucky.com/010031.html
« Reply #10 on: December 19, 2010, 06:58:14 PM »
Mine are 11-rib.   31 42 1 234 908 on my invoice dated 17 April '92.  That is the same part number Hucky has for the 11-rib.
I don't think I would want 13 ribs, as there would be too much material and they would restrict the full compression travel of the forks, as was pointed out to me by Duane.
I don't know who advised me on which boot to put on in 1992.
I had the bottom of the boots pulled "just over" the tops of the sliders, and Duane said to pull them down as far as they would go, to allow more free space.
They are pulled down, in this picture:
« Reply #11 on: December 19, 2010, 06:59:34 PM »
...Oh and in case he can't recall because he does get quite forgetful in his dotage, when Monte uses IIRC he means "if I remember correctly" but that's pretty much a crapshoot with the old coot. [smiley=shoot.gif]
I heard that.
Just remembered that I celebrated, at least I think I did, a geezer birthday a couple weeks ago, IIRC.
Monte [smiley=zzz.gif]
« Last Edit: December 19, 2010, 07:00:21 PM by montmil »
79beem
« Reply #12 on: December 19, 2010, 10:34:56 PM »
Thanks for the info Bob and Rob,
I did find these at Beemershop.com
http://www.beemershop.com/catalog/product_info.php?products_id=173
I counted 14 ribs but i don't know the dimensions.
 I will try and find a stockist for the 11-rib.   31 42 1 234 908
Here in oz first.
Looking at your pics Rob it doesnt look like theres anymore room
 between the forks and mudguard to fully extend the 13 ribber, unless
 the spaces between the ribs are smaller on the 13????
The plot thickens..............
Thanks once again guys for your generous input and efforts.
Regards
Ian
79beem
« Reply #13 on: December 19, 2010, 10:43:03 PM »
Oops!
How rude of me.
Thank you  Bengt_Phorqs, I'll be sure to contact you if i have any probs fitting the gaiters.
Regards
Ian
bruce_launceston
« Reply #14 on: December 20, 2010, 03:14:57 AM »
Hi Ian
Munich Motorcycles in Western Australia have the 13 rib gaiters on their online shop for $40 AUD and the 11 rib ones for $48.
http://www.munichmotorcycles.com.au/index.php?cPath=505_17_60_1035&osCsid=5be810dbee8330292604ca441baf5267
I have dealt with them frequently and they are very good.
Are you sure you need the gaiters, my personal preference is for naked forklegs.
Cheers Bruce
« Last Edit: December 20, 2010, 03:17:01 AM by bruce_launceston »
