Author Topic: Chrome Crossover Clamps -- How Does This One Look?  (Read 1958 times)
Ben_Carufel
« on: January 04, 2011, 01:56:22 PM »
I've got new Mac Whispertones arriving tomorrow so in preparation I removed my headpipes today for a cleaning up. Of course the crossover was a mess -- one side had both tabs for the clamping bolt broken off, and the other broke off upon removal.
I found these clamps online, and can have some tomorrow as a local Harley shop says they're placing an order from the supplier today anyways. 1 3/8" = almost exactly 35mm.
Since my crossover is cleaning up nicely, I'd like to use chrome clamps as opposed to just hose clamps. Think these would do the trick?
http://www.customchrome.net/icatalog/ProductDetails.aspx?sku=11218
Ben
Re: Chrome Crossover Clamps -- How Does This One Look?
« Reply #1 on: January 04, 2011, 02:42:57 PM »
They look ok, should you have to replace the crossover pipe the motobins chrome one has the clamp built in.Photo has the part number
Offline Mike V
  • 78 R100/7 , 81 R65
« Reply #2 on: January 04, 2011, 03:17:08 PM »
Ben,
If you're going to use clamps...have you looked into stainless steel instead of chrome?
-Mike V.
Mike V. / San Diego
'78 R100/7 (original owner)
'81 R65 (fully restored)
Ben_Carufel
« Reply #3 on: January 04, 2011, 03:20:57 PM »
Lou, it looks like 88425A is the 35mm version for R45/65. The photo you posted seems to be the larger 38mm/40mm version?
Ben_Carufel
« Reply #4 on: January 04, 2011, 03:23:00 PM »
Ben,
-Mike V.
I haven't -- I'm figuring the chrome ones will last until I tear the bike apart for a full rebuild, at which point I'll likely do brand new headpipes and all SS hardware...
Hell, for now I might just do the hose clamp thing. I'm also considering painting my crossover with high-temp silver or black POR-15/20 paint. I have both colors handy and am finally thinking that the crossover isn't getting as pretty as the headpipes. If I do that, hose clamps are kind of a no-brainer as I'd already be deviating from the all chrome stock look.
« Reply #5 on: January 04, 2011, 04:22:20 PM »
T-Bolt Clamps are very nice.  They are SS, they work like a hose clamp, but are much stronger!
I hope this link works.  I can't view "shopping" at work...
http://www.jcwhitney.com/COBRA-STAINLESS-T-BOLT-CLAMPS/GP_2015038_N_111+10211+600014666_10111.jcw
And Electrolux vacuum extension tubes can be had for cheap at dealers (ask for the broken ones).
Cut to length and add compression slots.  I.D. is perfect.
« Last Edit: January 04, 2011, 04:24:29 PM by Rob_Valdez_79_R65 »
Ben_Carufel
« Reply #6 on: January 04, 2011, 05:01:03 PM »
Yep, I'm familiar with T-Bolt clamps from dealing with my brother's old supercharged Mustang.
Electrolux vacuum extension tubes eh? No $@*#! You learn something new every day.
bruce_launceston
« Reply #7 on: January 04, 2011, 05:50:15 PM »
The 'T' bolt style clamps should be available from your local hydraulic hose supplier. They may be cheaper if they are not being sold as a motorcycle specific product.
« Reply #8 on: January 04, 2011, 07:11:19 PM »
I use these for the header pipe to muffler clamp on my R65s. Clamps up very snug and no rust. Me likey!
Offline Julio A.
« Reply #9 on: January 05, 2011, 05:38:55 AM »
When my Dad and I got the R65, the crossover pipe was welded into place.  ::)
The exhaust was a ***** to remove because of this.
Julio Alarcon
1981 R65
1976 R90/6
2001 R1150 GS/ADV
2015 TR650
