Julio, you still need to confirm why the switch toasted itself. Plug in a new switch and there's a possibility it, too, might cook off on you.
While you wait on a replacement, check the harness for damage, shorts to ground, continuity, all that good stuff. Could have been the switch itself failed and caused the short. Maybe...
Get your volt-ohm multimeter out and play detective.
