Author Topic: Final Drive Oil Leak  (Read 736 times)
« on: December 13, 2010, 02:17:19 PM »
I've had a small but constant oil leak from the final drive since I serviced it with oil around 5-6 weeks ago .
Originally I thought it was from the rear brake cam shaft .
I had problems with the rear brake, the dot that you align to be in the gap of the brake lever that slides onto the cam was in the wrong place, I inadvertently pushed the cam shaft in and caused the seal closest to the brake shoes to start leaking .
After I got that problem solved a leak reappeared about two weeks later .
I had just gotten back to work after five weeks of vacation, no one filled in for me while I was gone, so five weeks of work backed up on me, today is the first day that I've had off that I wasn't worn out from the 16 hour work days for the last three weeks getting caught up on work .
I cleaned off the final drive housing last night and determined this afternoon that the leak was coming from the gasket area between the final drive and swing arm .
It's a pretty simple junction, a thin paper gasket .
I removed the final drive and found the paper gasket cut to where there was about a 2-3 mm gap in the gasket at the bottom .
I assumed that during reassembly that somehow I messed up and cut the gasket .
After removing the gasket from the final drive, it separated like it was die cut through a bolt hole .
The hole in the center had been double cut when it was manufactured .
I didn't feel so bad about it now that I knew I wasn't at fault .
I bought two gaskets a week ago, my plan was to use two gaskets with sealer on them and that would solve the problem .
I removed the first gasket from the envelope and it separated in the same way that the failed gasket had .
The other gasket was in good shape .
If it hadn't been an easy fix, I would be a bit upset , if this had been a transmission instead .
But at least it's a warm day, at 1300 it's 87 F. (31 C.) in the garage . ;)
« Last Edit: December 13, 2010, 02:29:59 PM by Bob_Roller »
