There are several differences in my '79 that I have come across. Â This latest one has to do with the frame. Â Just so you know this bike was first sold in Germany and at some point later was imported into Canada.
If you look at this parts diagram from the A&S parts fiche (I really like their new fiche setup) you will see the standard frame for the '79. Â
http://www.ascycles.com/Illustrated_catalog2/MicroList.aspx?id=51897&catID=46&catname=46+Frame+and+mounting+parts My frame is different in that it has a couple of extra bolt holes in the lower part of the frame (one on each side). Â The holes are right through the frame as opposed to the motor mount holes that are in the standard frame. Â You can see in the diagram that the motor mount holes are in a fitting that was welded onto the frame. Â The additional holes that I have are located about 4 inches aft of the rear motor mount hole...just below the rear of the transmission. Â The two holes look like it is a factory set up...nothing Mickey Mouse about it.
Does anyone have any idea what the purpose of these two additional holes might be? Â It might give me some insight into the other differences I have on my bike.
Oh yes the frame number on the bike is a legitimate R65 frame number it appears because the RealOEM parts site recognizes the number for a '79 R65. Â Of course someone may have put the frame number plate on this frame somewhere along the line if they used a frame from another model.
Has anyone got any thoughts?
