Author Topic: Krauser bags  (Read 1143 times)
Offline steven m
Krauser bags
« on: November 12, 2010, 11:55:41 AM »
I recently picked up a set of factory rack mounts for my trusty 83 r65.  What appeared to be a lot of rust was mostly a crummy attempt to paint them.  A little work with a wire brush and they look great.  Bolted them on, mounted the racks inboard of the shocks.  When I put on Krauser bags, the turn signal hits the bag on the right side and I cannot get the latch to engage.  These are the classic airhead Krausers, not the more modern shorter and squarer BMW bags.  Have I mounted the racks incorrectly?  Hmmm...
Steve
Re: Krauser bags
« Reply #1 on: November 12, 2010, 12:04:36 PM »
Steve
The mounts may be for r80 or r100 which have a longer wheelbase...hacksaw may be required...
Re: Krauser bags
« Reply #2 on: November 12, 2010, 04:17:51 PM »
Some people shorten their turn signal stalks out of vanity.  I would say this is one situation where it might be necessary.
If the mounts went on without any real drama, they are probably O.K.  If they were made for a large-frame airhead, you would have had to modify them to get them to work.  It doesn't sound like that is the case, here.
Get yourself a dremel-type rotary tool to cut the slots after you shorten the stalks.  Watch where you make the slots so the turn signals are level with the pavement.
Offline steven m
Re: Krauser bags
« Reply #3 on: November 13, 2010, 11:47:06 AM »
Thanks for the input.  The racks are for an R65.  I believe older airhead racks have a vertical forward mounting tab and mounting hole.  The R65 racks have a horizontal tab and mounting hole.  The racks for the later single shock R65 and R100 are different.
Maybe a couple of thick washers on the rear mount, the center loop on the rear subframe, would move them out about 1/4 to 1/2 inch.  That is all that is needed.
I'll keep you posted.
Steve
Re: Krauser bags
« Reply #4 on: November 13, 2010, 04:28:06 PM »
Maybe a couple of thick washers on the rear mount, the center loop on the rear subframe, would move them out about 1/4 to 1/2 inch.That is all that is needed.
That is what I did on my original mounts.  A long time ago, I already had a Reynolds rack on my bike when I bought a set of BMW Krauser bags with mounts.  I didn't know I needed the Reynolds loops to work properly.  So I got out the grinder and made them fit.  (not recommended)
This is what my rear mount looked like.  The saddlebag mounts are on the outer edges of the spacers:
click on pic for more
