Author Topic: Brake caliper overhaul - R65 1981  (Read 2290 times)
Offline NorR65
« on: October 09, 2010, 11:15:29 AM »
I can not push the pistons back in the caliper, not even with pliers.
I have opened the bleed screw and then pushed the pistons back but with no success. The calipers need to be overhauled.
My first question: My Hayes book tell me to split the caliper before I removes the pistons. I think I read in an article by Snowburn that it can be difficult to align the two halves and avoid leaks.
Can I get the pistons out without splitting the caliper?
Any good ideas how to overhaul the calipers as easy as possible?
Thanks
Online Bob_Roller
Re: Brake caliper overhaul - R65 1981
« Reply #1 on: October 09, 2010, 11:24:07 AM »
There's an o-ring between the caliper halves, that should be replaced .
With the caliper assembled, I don't think you can get the pistons out of the caliper.
If the pistons are seized in the caliper, disassemble the calipers and use air pressure to remove the pistons .
Use caution when doing this, as the pistons can come out with a lot of force, make sure you have something to stop the piston and contain the fluid that is still present in the caliper, otherwise you will have a real mess to clean up .
« Reply #2 on: October 09, 2010, 11:34:33 AM »
It is probably just a real mess inside.  That is what I found.
I had no issues with alignment.  Although my 1979 came with ATE calipers, they are for the most part identical to the Brembos.
click for more pictures
Do yourself a favor, and rebuild the entire system at this point.  That includes replacing the flexible line.
Most folks go with stainless steel braided line, these days.
Offline NorR65
« Reply #3 on: October 09, 2010, 12:02:55 PM »
My calipers are ATE. Do they too have an o-ring between the caliper halves? If the calipers and hoses looks as messy as the master cylinder reservoir inside then its a wonder that the brakes functioned at all.
« Reply #4 on: October 09, 2010, 12:17:26 PM »
Yes
If your pistons are stuck in the caliper the only way your going to get them out is with pressure behind the pistons. Safer with hydraulic pressure if you can so don't drain the fluid out before you start. Just use the brake lever to force one of the pistons out. When I overhauled my caliper I managed to force the RH  piston out before splitting the caliper then replaced the O ring with a rubber disc to block off fluid from the RH side of the caliper after reassembly which then allowed me to pump out the LH piston with hydraulic pressure.
I had no problem with leaks from the O rings. Actually if I remember correctly it's a square section ring.
If you have some corrosion on the piston and it's not too bad you can polish it out and you will be OK. It's the piston seal that keeps the fluid in not the piston itself. The caliper bores have to be good though.
« Last Edit: October 09, 2010, 12:32:28 PM by bhodgson »
Offline NorR65
« Reply #5 on: October 09, 2010, 12:36:23 PM »
My master-cylinder is dead, will not hold pressure.
I guess I have use some form of air to free the pistons.
I start to take the brakes apart tomorrow. Then I will see what parts I need to order.
« Reply #6 on: October 09, 2010, 12:39:19 PM »
Sorry
I hadn't read your other thread on the master cylinder problem.
Offline NorR65
« Reply #7 on: October 09, 2010, 12:55:37 PM »
No need to be sorry Barry.
I am really happy for all help I have got from you and everybody else on this forum.
Offline Mike V
  • 78 R100/7 , 81 R65
« Reply #8 on: October 09, 2010, 02:46:08 PM »
Nor65,
Here's some photos of what you can expect when and if you get inside your ATE' calipers.  Best way to free the pistons is secure the bleeder valve, insert a loose fitting block of wood in-between the pistons with the pads removed, secure the caliper in a vice carefully and apply compressed air through the delivery line port.  Be VERY careful, the pistons will release with violent force.  Keep your fingers out of harms way. Be sure to clean everything very very well.  Rob's pictures look a lot like mine when I opened up my calipers after 15 years of storage.  Looks a lot like gravy in there.  Cleaning things thoroughly is key.  I don't use any lube other than brake fluid for re-inserting the pistons and new square o-rongs.  Be sure to line-up the pistons with the bores  as close as possible.  I've always been lucky with my caliper rebuilds, the pistons and square o-rings have gone back in with thumb force.  Don't use a hammer!  The small caliper o-ring for the caliper halves are unavailable as far as I know.  I think Bob was able to find some in a specific kit somewhere if my memory serves me correctly.  If not, I have hundreds of replacements that will work fine you can have for free.  I'm more than happy to mail them to you if needed.  Below are some links to my brake rebuild and an essay (pdf attachment) on the o-rings I wrote up a while back with Oak's review.  Hope the pictures help or at least give you an idea of what to expect.
 http://s428.photobucket.com/albums/qq8/gruntyman66/81%20R650%20Restoration/Front%20Brakes%205-09/?start=0
« Last Edit: October 09, 2010, 02:48:55 PM by Mike_V »
Mike V. / San Diego
'78 R100/7 (original owner)
'81 R65 (fully restored)
« Reply #9 on: October 09, 2010, 07:35:01 PM »
Nice write-up, Mike!  I remembered someone having a bag of o-rings, but I couldn't remember who.
I did mine before yours, and I ended up re-using my small o-ring.  I didn't remember it being a square section, though.  But that was 4 years ago...
Online Bob_Roller
« Reply #10 on: October 09, 2010, 07:40:37 PM »
Motobins has the o-rings for those of you in Europe, or OZ .
The o-rings that go between the caliper halves a round in cross section, the seals that into the caliper and seal against the piston are square cross section .
« Reply #11 on: October 09, 2010, 08:57:08 PM »
Mike V's PDF write-up seems to indicate he found a square section o-ring between the two caliper halves, and he settled for a more typical round cross-section o-ring.
Offline Mike V
« Reply #12 on: October 09, 2010, 09:12:55 PM »
Rob,
The old caliper o-rings I removed seemed to be square in profile.  Don't really know if the originals were round or square.  I looked at them very closely - it's very possible they were originally round and over the years formed themselves to appear square under years of compression.  The replacements fit perfectly with just the right amount of bulk for good sealing compression.  I have over 1500 miles on the bike since the rebuild and since the article was written.  No caliper drips, leaks or errors.  I couldn't be more pleased with the brakes on this bike!  It's one of the things I enjoy most about riding the R65...it's ability to stop with very controlled lever modulation and good feel & feedback.  Don't understand why the ATE's get such a bad rap.
Mike V. / San Diego
« Reply #13 on: October 09, 2010, 11:46:44 PM »
It is the "swinging" ATE's on the /6 & /7's that had the bad rep.  But I think that is because they required a special logic to setting them up to work best.
Here is a picture from Stephen Bottcher's website.
« Last Edit: October 09, 2010, 11:50:19 PM by Rob_Valdez_79_R65 »
Offline NorR65
« Reply #14 on: October 10, 2010, 02:22:03 AM »
Mike V
Thanks for the offer of o-rings. May be I will need 2 o-rings.
When I bought the R65 I got a few spare parts, including some small o-rings for a Brembo caliper, I will measure them, may be they fits ATE calipers also.
Since I have no compressed air, is there another way to loosen the pistons? Pliers? Grease gun?
