So far only having the drive shaft fill plug threads repaired on the final drive housing for $120US has been the biggest single expense .
Next most costly part was a Dyna 'brown' coil, as the original grey coil was still installed (numerous cracks in the case) as well as the original ignition leads .
The speedometer needs repair, from the looks of the crimped ring on the bezel, some-one's already been in there, so that could turn out to be a bit pricey, but I've got the speedometer from the '84 LS if it's not worth repairing .
Next week, when ever the parts from Motobins show up, the transmission is coming off for a spline lube, if I get away without having to get the transmission overhauled due to worn splines, I'll feel lucky, but with what I've seen so far, I'm not overly optimistic .
I've got a throttle tube, throttle cam and chain assembly, throttle top cover on the way from Motobins .
After getting the fairings off, it appears that the all of the throttle cables, clutch cable and speedometer drive cables require replacement in the not too distant future .
All of the numerous parts that I've gotten so far, seals gaskets, nuts bolts etc. have cost about $500, so I'm not doing too bad so far .
If I didn't have a completely rebuilt front brake system I'd be looking at around another $600 for that .
